How can i make the tail on my polaris 3900 start sweeping again
It is the first time i have used it this year and the tail seems to have a red tint to it
  • 556 Answers
SOURCE: Sanyo Tv color problem
Hello, The TV is four years old. About two weeks ago the screen suddenly had a complete red tint. I tried adjusting the color settings but nothing really improved. the next time I turned it on, it was fine. But the time after that it turned red again. Now it more and more often has a deep red tint. Any advice? Thanks please do not adjust any thing. your problem is in red color cathode ckt it might be loose contact in red cathode. crt base might be loose. check red output supply. signal line from chroma ic to crt base. regards thanks
Posted on Sep 11, 2007
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
  • 333 Answers
SOURCE: If i have a polaris pool sweep system can i still
yes
Posted on Jun 09, 2010
thepatioman
  • 52 Answers
SOURCE: My Polaris 3900 sweep hose simply drags behind the
The hose connected on the interior of the polaris could be disconnected. seperate the housing and you will see the hose. Or you need more pressure at the wall. Try closing are reducing the amount of flow to the skimmers to up the flow at the wall connection. Your back up valve should pull the polaris off the steps. Set the rotating jet propulsion on rear to 11: 00 position.
The Pool Tech
Posted on Jul 14, 2010
jharwell668
  • 640 Answers
SOURCE: polaris 380 sweep hose isn't
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Posted on Mar 17, 2011
Do the Polaris 3900 tires ever need to be replaced?
It would be incredible if the machine lasted that long to replace the tires but t is possible. If you use it frequently and have run it for ball park 5 to 10 years then I would look at replacing them. Simply take a look at a replacement tires treads. if your are 50 percent or more worn I would get new ones.
Jan 03, 2016 | Polaris 3900 Sport Automatic Pool Cleaner ...
Polaris 3900 pool cleaner tail does not swish
allen wrench on back on bottom turn out till active enough
Jan 17, 2013 | Polaris 3900 Sport Pool Cleaner ()
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 3900 sweep hose simply drags behind the vacuum. I've adjusted the sweep jet, but it doesn't appear to do anything. I'm also finding that the vacuum is gettin hung up when it gets to a the...
The Pool Tech
Jun 13, 2010 | Polaris 3900 Sport Automatic Pool Cleaner ...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
