Question about IFB Washing Machines
Why my IFB washing machine not sppinnig &shows E2 code
  • 44 Answers
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
Posted on Aug 08, 2009
  • 414 Answers
SOURCE: IFB washing machine dryer not working
can you supply the enr?
first port of call is the overheat stat, switch off mains remove lid and in the middle top of the unit there should be a metal chamber that houses the dryer heater, somewhere there, you will see a stat that should have a reset button on it, if you press the button and it makes a definate click, it was tripped. There are some reasons for this, you may be stopping the dryer early and not letting it do the last 10mins which is a system cool down, the fan is not operating or slow, the unit is not draining properly (check pump filter) or you are trying to dry more than 2.5kg (half a load).
Good luck.
Posted on Jul 08, 2010
  • 1417 Answers
SOURCE: my new omega washing mashine
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Posted on Jul 30, 2011
caroldon
  • 17130 Answers
SOURCE: fault code E2 on midea
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 08, 2011
  • 15 Answers
SOURCE: i have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Posted on Apr 20, 2012
IFB washing machine showing dl er...what can I do ?
Mar 20, 2017 | IFB Washing Machines
In ifb top load washing mechine it gives e2 error code
Google the Make and error codes or search for a video on YouTube
Jan 09, 2017 | IFB Washing Machines
Sir E4 code open help me ifb aw60-8061
There is no matter with this error code. Just switch OFF the device and switch it ON only after 48 hours. It will reset itself. If the error code is E2, there is no need to make it right. It has gone. Buy an other one.
Aug 29, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
I have ifb wasing machine which shows error code as E 6 where coin trap is free
if U R in india call 18604255678 or search for customer care # & call them
Jul 30, 2014 | IFB Washing Machines
My ifb washing machine is showing dp error
Jul 05, 2014 | Washing Machines
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
32 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Tall Tiger
Tall Tiger
Eric Sutherland
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
