How to bring up all channels and programmes of whats on tv on a 55 Changhong television
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
Why tv guide shows channels but stopped showing the programmes that are on, and info about them. Also sometimes brings up different channel to selected one.
Yes. I have experienced the same problem from time to time, but not allot. It usually occurs when the cable company is performing an update to where all channel descriptions will display the words, "no info". Sometimes it occurs around 12 midnight. Sometimes there is a lag in time (5 seconds) from when I push the button to go to a channel from the guide, and when it actually happens (but again, not all the time).
Nov 09, 2014 | Televison & Video
What channel is nbc on vizio
The Brand of TV does NOT Change what order the channels are in. Channels are on the same channel no matter what brand tv you have. Look online for Tv with your zip code after it this will get you all your channels in your area. Or ask your cable provider for a channel list.
Oct 01, 2014 | Televison & Video
What is the solution to a sharp tv that does not show uhf programme?
The cheapest solution is to buy a cheap external freeview box and connect to the TV using a HDMI port to receive the UHF channels
Jun 30, 2014 | LG 55LH40 55 in. LCD HDTV
Why can't we get a channel of our bought television?
First, is the antenna to which your TV is hooked up working? Are the other three on you block receiving TV channels? The signal from the antenna has to be split four ways, so you need to use a four-way signal splitter and probably a signal booster/amplifier. It is probably wise to have a professional TV antenna installer at least access your setup and make suggestions.
May 12, 2014 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
How to open changhong tv service mode
hi I want to repair my changhong tv,,how much pay to service?and where to call
Oct 28, 2012 | RCA HD52W58 52" TV
My TV is Changhong 21K55EA. Now my TV is lock none of keys are working in remote and in TV too. In TV shows lock sign only. Please help me. Thank you.
Hi, Try unplugging it for 1 hour this should reset the lock. If this does not work bring it to be serviced at your local repair store.
Jul 14, 2011 | Televison & Video
Cannot tune in programmes I go to menu which brings up screen picture, audio, time but skips on tuning into progs and goes to options. Please help.
Select TV as input source by TV remote or push Channel button on remote then go to TV Menu. That will enable Tuning menu in TV.
Jul 28, 2009 | Televison & Video
Remote problem
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Aug 24, 2007 | iLO 2600 Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
