Question about Cameras
My ADS Digital Photo Frame Model No. ADS7010PF will not shot photos that are on the card SD card i have in it...only shows internal memory photos. What can I do?
4 Suggested Answers
SOURCE: can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
Posted on May 09, 2008
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
SOURCE: Saving photos to internal memory on ultech digital photo frame
go to http://camera.manualsonline.com/ex/thread/view/idthread/1339017
lots of good instructions, I got mine working already
Posted on Feb 01, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Does the digital photo frame have it's own internal storage, or do I need to purchase an SD card?
Most digital photo frames have a small internal memory limiting you to the amount of pictures that it can show. If you want to have a slide show of a couple of hundred pictures or more then an SD card would be a good idea.
Regards.
Jul 27, 2009 | Coby DP-768 7-Inch Widescreen Digital...
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
How many photos can be stored on a digital photo frame?
I generally depends upon the size of the picture that you are storing and the memory card that in the digital frame.
eg 128 MB photo frame ,would store close to 10 pictures at 8 megapixel resolution
Apr 14, 2008 | Computers & Internet
Trutech digital photo frame
Most digital photo frames do not have internal memory and require external media to be plugged in permanently. Only the expensive ones have there own memory and usually not a lot.
Get an SD card and move your photos to it, that way you won't need to have the USB drive sticking out of the frame. That's if the frame has an SD slot.
Jan 14, 2008 | Electronics - Others
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
