Why can't I see your answer in my comp. - Computers & Internet
I just asked about my washer vibration and did you answer my comp. kicked out and I did not get my answer
Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 11, 2015 | Washing Machines
Well look my comp overheats and shuts off when ever i play high-end games because of the heat so i updated my bios to 1.25 then it still overheats and now i get the blue screen error. my comp crashed 3...
this like the over heat section is your processor, not your bios
open your laptop, the replace your processor fan with new one
may be it will solve your problem
i hope this helpful
thank you for using fixya
Feb 23, 2011 | Acer Aspire 5720-6661 Notebook PC
I have a GE frig., and I turn it off since the house was empty for ~2 months. Now the frig is not working. How can I re-start the frig.? I assume it is the compressor that is off too long? Just read...
u say GE model says MAYTAG ok which one? two months turned off not a long time for comp.. probaly it is your timer it might need to be turned till comp. comes on. if that is it than replace defrost timer..ok
Feb 12, 2011 | Maytag MSD2756GES Side by Side...
I cannot sync my iphone 3G with ituines. ive tried everything but it still doesnt work. itunes sees it as charging but does not show anything else in devices
try updating your itunes and resetting both comp and phone (turning off then on) and connect up, if your not having any luck try a different cable, also try with another user account on your comp with administrative access or try another comp all together, cant give you a definite answer on what it is until there's been a bit of "troubleshooting"...by all means give it a shot and if you cant sort it just message back :)
Feb 06, 2011 | Apple iPhone 3G
I have a gateway comp 500se i purchased in 2002 and everytime i want to format my disks have problems im needing the driver cd and the operating systems cd without having to purchase another one since this...
You should be able to download the drivers from the gateway.com site if you enter your serial number. The OS is another story...you're supposed to save those cds in a safe place..
Here's a guide to the reformat, though that won't help if you don't have the cds.
If you're having problems with malware, I recommend these removal protocols. They may just save you a reformat...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | Computers & Internet
Need help finding the CPT Button on the Sharp EL 738
CPT does stand for COMPUTE, on other calculators this is the COMP button, same thing, different name.
Mar 08, 2009 | Sharp EL-738 Scientific Calculator
E-machine computer will not shut down
your files might have been corrupted i know the end close screen file sometimes and will get corrupted quicker than startup screen
now the question is was this the floor model or a straight out of the box unopened comp cause floor models always needs to be reformated those are the show comps. people play with those all day once you reform. comp. and put in new O.s. system everything should come back to working perfectly and dont forget spyware checkers and virus blockers name branded backed up these will help protect your comp
simple other solution might be you just need to upgrade your system files threw windows update
May 07, 2008 | Nexus Prolong:Extra Cooling after PC shut...
Black and White screen on TV When connecting the laptop
never tried an adapter before .
likely the color signal is just too low or missing in the adapter mixer circuit.
just be certain that you have the display set for 60hz refresh rate in you display properties/adapter
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
