Change my password - Computers & Internet
I need to change my password
hi William.
you have not said what password you want to change but see if this is it.
How do I change my password on Google? Change your password
  1. Sign in to My Account.
  2. Under "Sign-in & security," select Signing in to Google.
  3. Choose Password. If you see a prompt to sign in again, sign in.
  4. Enter your new password, then select Change Password.
Change or reset your password - Google Account Help - Google Support
https://support.google.com/accounts/answer/41078?hl=en Search for: How do I change my password on Google?
if not go to this link should help you out.
how to change my password Google Search
Dec 03, 2017 | Computers & Internet
Tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 | Computers & Internet
Change password on yahoo
Method 1 Changing Your Password (Desktop)
  1. Log into the Yahoo! Mail website. ...
  2. Hold your cursor over the Gear button in the upper-right corner. ...
  3. Select "Account Info." ...
  4. Click the "Account security" menu. ...
  5. Enter your password. ...
  6. Click the "Change password" link. ...
  7. Create a new password. ...
  8. Sign in with your new password.
3 Ways to Change A Password in Yahoo! Mail - wikiHow
www.wikihow.com/Change-A-Password-in-Yahoo!-Mail Change password on yahoo Google Search
Dec 15, 2016 | Yahoo Computers & Internet
How can I change my password for my g mail
There should be a forgot password link below the password blank on the login.Click the link and follow through the steps to change your password . However you might need a second email already linked to your gmail.
Nov 25, 2014 | Cell Phones
Evelynwms132GMAIL.COM
Change your password on a phone or tablet
  • Go to accounts.google.com/EditPasswd.
  • Type your current password and your new password.
  • Touch Change password.
Change your password on a computer
  • Open Gmail.
  • Click the gear in the top right.
  • Select Settings.
  • Click the Accounts tab at the top.
  • Click Change password in the "Change account settings" section.
  • Click Change password.
Source: https://support.google.com/mail/answer/6567?hl=en
Hope that helps!
Jan 30, 2014 | Computers & Internet
Change my yahoo password
Change your password Your Yahoo password applies to all Yahoo services you use with your account. Because of this, we think it's a good idea to change your password at least once every year to keep your account information secure.
You'll need to know your password before you can update it. Not sure what it is?Use our Password Helper.
Here's how to change it:
  1. Go to your Yahoo Account Info page.
  2. Enter your Yahoo ID and password.
  3. Under "Sign-In and Security," click Change your password.
  4. In the fields provided, enter:
  5. Click Save.
+Changing the password for your Yahoo partner email account
Dec 13, 2013 | Computers & Internet
Change my password on my facebook
Changing facebook password is not a troublesome task. You can easily change your facebook account password through following steps:
·Go to the facebook.com
·Login into your facebook account
·Then click on settings
·Tap on general settings
·Then click on edit password
·Submit current password
·Then Submit new password
·Re-submit new password
If you want to read more about changing facebook password so you can visit the given link and get complete steps about it. Visit here: Know More About Change Facebook Password
May 01, 2013 | Computers & Internet
Kos change password
k.o.schange password
Apr 23, 2011 | Dryers
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
