Question about Dyson Vacuums
Does the dyson cordless Hoover come with screws to hang the docking station
Inherited from family member who moved away, can't see how the charging cord fits into docking station as it doesn't line up with hole on vacuum body when inserted into docking station.
Hi there, it's Jack at Dyson.
All DC59 models were supplied with the docking station design shown below, which sounds as if it's the one you've seen in videos online:
From your description, it sounds like the docking station you've inherited may belong to an older Dyson cordless vacuum, such as DC35 or DC44. If you're able to call the Dyson Customer Helpline directly, we should be able to help determine exactly which docking station you have, and whether or not it's compatible with your DC59.
You can reach our experts by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
May 07, 2016 | Dyson DC59 Animal Cordless Vacuum Cleaner
How to fit wall bracket
When installing DC59's docking station, use appropriate hardware/fixings for your wall type and ensure that the dock is mounted securely. Ensure no pipe work (gas, water, air) or electrical cables, wires or duct work are located directly behind the drilling area. The dock must be mounted in accordance with all local laws and regulations and applicable codes and standards. Dyson recommends the use of protective clothing, eye ware and materials as necessary.
The charger cord assembly attaches to the docking station as shown below:
I hope this information helps. If you need any further guidance, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Have mislaid instructions for docking station wall mounted for dyson animal doc 59. Where can I find please ?
Just to confirm, were you looking for directions on installing DC59's docking station? If so, please email me directly at help@dyson.co.uk so I can provide you with these, and answer any other questions you may have.
I'll look forward to hearing from you.
Feb 16, 2015 | Dyson Vacuums
How do I get charger out of docking unit
If you have your docking station installed on a wall, you'll need to remove it from the wall before you can remove the charger cord. Once it's removed, releasing the charger cord from the rear of the docking station should be straightforward, but if you'd like our experts to talk you through this we're happy to do so.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 12, 2014 | Dyson Vacuums
Insert charger lead in docking station
This diagram should help you attach DC59 Motorhead's charger cord to the docking station correctly:
However if you'd like some additional guidance on this from our experts, you're welcome to contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC59 Motorhead Bagless Cordless...
How do you remove the battery on the DC44. There is no push button to release it.
Like all current Dyson cordless and handheld vacuums, the latest version of DC44 features a battery which is fixed in place, and isn't designed to be removable on a day to day basis. This helps ensure a robust connection between the battery and the main body assembly.
Between uses, you can recharge the vacuum in the wall-mounted docking station, or plug the charger cord directly into the machine.
It is possible to remove the battery if you ever happen to need to replace it with a new one, but otherwise we would advise against removing it from the machine.
I hope this helps, but if you'd like further advice from our experts, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
You can also find a lot of useful advice on using and maintaining your machine by visiting http://www.dyson.com , clicking 'Support' and selecting your machine from the list.
Mar 15, 2014 | Dyson DC44 Animal Cordless Vacuum
Green light on DC44 but nothing is happening
Hi Emma, it's Jack at Dyson.
I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 01, 2014 | Dyson DC16 Root 6 Bagless Handheld...
DC 44 animal wont charge. Charge light comes on then off after about 30 seconds.
Hi Darren, it's Jack at Dyson.
I'm sorry to hear you're having difficulty recharging your DC44 Animal. It should charge from flat within 5.5 hours when connected to the charger assembly, or placed in the docking station, as shown in the video above.
The charge light will turn off once the battery is fully charged. If it seems to be shutting off prematurely, we would need to take you through some quick diagnostic checks when you have the machine to hand. This will help us confirm what may be needed to resolve the issue.
Please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA), to speak directly with our team of experts.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Oct 27, 2013 | Dyson DC44 Animal Digital Slim Cordless...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
