Question about HP Measuring Tools & Sensors
I have an Ariens Zoom mower, and I can't get it to fire. It will turn over, and there is spark coming from the plug. I have detailed the Carb. almost spotless.
I am very confused because it is getting the three main things, Air, Gas, and Spark. Is there something I am missing? This is a 13.5 HP Briggs and Stratton engine.
    Champion:
    Habit-Forming:
  • 211 Answers
Are you sure it's getting gas? What does detailing the carb mean (cleaning the outside or the inside/)
some makes of carbs BS used, at least in the past, would develope sticky float/needle valves. When you remove the plug after sustained cranking, but no start, it should be damp with gas
Posted on Jun 19, 2017
5 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: carb is getting clogged and spark plugs fouling
Carburetor cleaner will ruin the rings and do that.
Posted on Apr 13, 2010
SOURCE: Briggs and Stratton 6.5 hp won't start- not sure
Took carb. off and cleaned and put new kit in. Carb. is self choking. Put new primer bulb in. Will run with starting fluid then stop. Not getting any gas. Could carb. be clogged. I soaked it in carb. cleaner and blew out. Any suggestions would be greatly appreciated.
Posted on Jun 04, 2010
  • 24 Answers
SOURCE: Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Posted on Jun 30, 2010
  • 6468 Answers
SOURCE: Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
Posted on May 10, 2012
Key just clicks the solenoid. bridging solenoid engages starter and turns over. new spark plugs.
Make sure the key is providing good power to the solenoid. If it is the the solenoid is bad.
Jul 31, 2016 | Ariens Garden
Turn over good but no spark at plug
The coil pack is faulty it could be spark plug it could of come. Loose on the mount under the fly wheel
Jul 03, 2014 | Ariens 34 In. Zoom Series Riding Mower
We have a 924056 ariens 10hp snowblower. It wasn't get gas to the spark plug and we took the carb apart and all is clean, clear and good. We are wondering if the governor is bad but cannot find any manuals...
Sounds like needle valve on carb. float sticking ,initial settings for tecumseh eng. is main jet , or the one on the bottom of bowl is 1 and 1/2 turns out after gently seating it . the low speed jet on the side is 1 turn out after gently seating it. may also want to check fuel filter and check vent on fuel cap. hope this helps
Jan 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Engine turns over but no spark at plug. changed plug , still no spark. On 18hp courage sv470-610. note: has no oil sentry pressure switch.
Ok, the way to trouble shoot your electrial system on your mower is first unplug the wiring harness at the engine. Now pull the plug or pluggs and put one plug in the plug wire and ground the plug to a paint free place on the engine. Now using a jumper cable (you only need one) from the mower battery postive post and push the other end to the bolt on the stater that holds the red wire on the starter. Watch the plug to see if it is firing . If not you have a bad coil, but if it is you have short circut in the switch or wiring.
Sep 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
May 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
Apr 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower wont start problem is with carb i think. need a manuel
need more info like is the engine spinning over and not cranking, if it spinns over check for spark at the spark plug, if you have spark you now have a fuel problem, if it doesnt spin over at all its probly in the battery or starter. to find out if its a fuel problem just spray carburator cleaner in
too the carburator it dont take much, then try cranking it and see if it runs if it does more then likely the carb needs to be taken off and cleaned, agaian not that hard of a job, just get the carb off and brake it down and spray carb cleaner in every hole in the carb,,,, good luck
Mar 25, 2009 | Ariens 34 In. Zoom Series Riding Mower
Old craftsman snoblwr stalls after 5 min use
More likely the fuel filter either air locked if a bowl or dirty and neds to be replaced for sitting around unused. Itf that doesn't work. remove , dissemble and clean the carburator.
Jan 11, 2009 | Ariens 34 In. Zoom Series Riding Mower
Measuring Tools & Sensors Logo
1,022 people viewed this question
Top HP Measuring Tools & Sensors Experts
obsteiner
john h
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
