Question about Exercise & Fitness
I have a Orbit fitness treadmill that stopped working while In was using it, and came up with E1 on the screen. Now it won't work. Model is T920i and seriel # 0606 00125
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
maxtreadmill
  • 832 Answers
SOURCE: I have a v-fit PST-04 treadmill, model no DK 2510.
Most E1 codes are speed sensor or no belt movement.
You wil lneed to unplug your unit the remove the motor shroud then plug unit in most Motor Control boards have LEDs. First thing I would do is start the unit look down at the board one of the light should start flickering this is a signal being sent to the lower board from your upper console. This tells me that the upper console and cable connecting the upper and lower boards is working also notice if the drive motor moved if not then E1 will come up. Now turn your unit off then turn back on to reset , next manually push with one of your feet the belt you should notice another flickering light the faster you push the light will flicker faster this tells me that the speed sensor is working if not replace the speed sensor. Next procedure check the motor using a fully 18v drill battery or car battery which ever is handy connect the two motor leads usually red and black in some cases black and white to the battery, if the motor move at a speed of approx. 1 mph then you have a good motor if not you can have worn motor brushes or open winding the motor.
If the upper board and drive motor are good then the only thing left is the motor control board if you have a multi meter handy connect the lead to the two spades that motor lead came off of the press start you should get a DC voltage of about 5 to 10V DC if not replace the board.
Posted on May 31, 2010
I have a bh fitness treadmill model number G6414v and its got an e-02 and e-07 error on screen . What do I do
I don't know what this has to do with washing machines???
On your BH F1 treadmill here are their listed errors.
E1
Possible cable fault.
Connect the wire well between top
controller and bottom controller
E2
Burst clash.
Operating with incorrect voltage; Connect
the motor wire again.
E3
No speed sensor signal
Replace the sensor light on the bottom
controller or speed sensor.
E5
Possible motor overload.
Lubricate the belt.
E7
Safety key.
Insert the safety key.
Here is the manual, page 12 is the troubleshooting and error codes in English.
http://www.bhfitness.hu/shop_ordered/69670/pic/english-manual/G6414U_Monitor_manual_v2-3226.pdf
Jul 26, 2016 | Exercise & Fitness
Not working at all. What does error e1 indicate?
HI There,
We would need to know the make and model of the treadmill as they are vastly different electronics wise. The error E1 can indicate a mismatched speed error, no belt movement when it is expected, or a faulty lower control board may also cause this. Older Matrix Fitness machines used "E" for elevation errors and "S" for speed errors but most have changed that format to E1, E2, etc..
Good Luck!
Apr 25, 2016 | Exercise & Fitness
I don't have users manual for pro fitness tread mill keep getting a fault saying E1
https://www.google.co.uk/search?q=Star+Trac+Pro+S+Treadmill+manual&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-N_0VMutKufR7Qb_-IHgDw
youll find the manual
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
I keep getting an e1 error on the display.
Hi normally this error is coming from speed sensor in the main motor, and problem with the motor.
see the attached video. LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Dec 14, 2017 | Nautilus T516 Treadmill
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 05, 2010 | Startrac Fitness Products Star Trac 3900...
My tunturi treadmill 661f is showing E1 on the
May 16, 2010 | Exercise & Fitness
Tredmill error code
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
