Machine is GHH mining machines,drills underground mines,pump attached to the machine
  • 51 Answers
SOURCE: How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
Posted on Mar 27, 2008
barkencoa
  • 3463 Answers
SOURCE: I need a manual for a Creda Simplicity 1000
In your browser bar, type in:WWW.HOTPOINT.CO.UK.
Click on after sales, and follow links.
Pease rate my solution.
Thanks.
Posted on Aug 10, 2009
  • 16 Answers
SOURCE: can the Model HEM 780N3 be calibrated?? Mine
Cannot be calibrated.
Posted on Jan 12, 2010
mhkamran
  • 180 Answers
SOURCE: I need to replace the filter in my Robinair 34700Z
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
For user manual you can try to robinair web official site www.robinair.com
Hope this will help you.
Posted on Apr 21, 2010
SOURCE: Reset Fisher and Paykel washing machine
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
Posted on Oct 01, 2010
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
How does a drive guide work
You attach it on the machine after you have attached the drill bit. If the drill bit is 100 mm for example (4 inches) and you want to drill 50mm (2 inces) only then you make the drive guide to be 50mm (2 inches) ahead of the drill machine.
Aug 27, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My Fog machine will heat up, and say it's ready, but when i press the button, it makes a buzzing noise and no fog will come out.
This is kind of late but I have one here now and the same thing...only difference with mine is that the green ready light will not come on either. I managed to get mine to output fog. I had to remove the hose form the pump inlet and bleed it to get the air out of it. It is like syphoning liquid from one container to another so to speak....fill the container with liquid, fill up the hose with liquid so that there is no are trapped in the hose, attach the hose to the pump and then submerge the other end into the tank. Turn on the unit and let it heat up. it should work ok..unless you have a problem with the pump itself..
Jan 18, 2011 | American DJ Fog Storm 1200HD Fog Machine...
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Hi my Gaggia Classic is not pumping water out of the perculator head, I have flushed the screen and the motor is running ok and the steam attachment works fine?
If you can get hot water from the wand, then the problem is in the boiler fitting that feed the head, try descaling again, or remove the screen and diffuser and clean area or backwash machine.
Apr 09, 2010 | Gaggia Classic Espresso Machine
What exactly does F 21 flashing on washer mean?? What do I do?
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller.
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The machine Steams ok, But no coffee or hot water comes out! I turn on the coffee switch, the maker busses, but nothing comes out!
I had this same problem with mine and was able to get it fixed. Here's what I did: There is a water pump that can get stuck from not being used for a while, especially if you have hard water.
Unplung from power & allow the machine to cool completely. I carefully took the machine apart and follow the tubing to locate the pump (mine was about 2-1/2" to 3" long X 1/2" diameter. Remove the pump, disassemble it and carefully clean all the parts. You will probably find 2 parts that are stuck together (I found a plunger & check ball that were stuck from water drying out in it).
Sep 10, 2009 | Coffee Makers & Espresso Machines
Neff dishwasher will not switch on , checked fuses etc and positive that power is going to the machine but will not switch on,is there any safety feature such as blockage or otherwise stopping machine from...
Just went through this myself. It could be a latch switch. Open the door undo the screws that holds on the inside door panel remove the latch. The 2 black boxes with wires attached are the switches. Take them out (use your camera so you know how to put back together), take to an appliance parts place, and have hem check them. Mine were fine saving me $42.00. If this isn't it (as mine wasn't) check the in-line fuse. From the switch follow the wires into the electronics box (you will have to remove the cover. The fuse on mine was attached to the top of the circut board and it had two Tan wires attached, one of these wires attaches to the latch switch. I had it tested and yep it was bad for $12.00 I had a working dishwasher, saving me lots of $$$$$$$. I hope this helps..
Jul 25, 2009 | Neff 24 in. S4443 Built-in Dishwasher
Water leaks from bottom of machine
is the gasket on the filter in one piece or has a line come off the pump? mine it was the output of the pump.
Feb 02, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine is leaking from the bottom
try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Nov 13, 2007 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
