Spin light won't turn off and we can't start another wash?
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: won't wash;lights flash on spin speed ,wash
F09 means "overflow failure"
FA means that a leak has been detected.
Disconnect power and dry water from inside. While power is off you can also check the drain hose at the back. To verify that the problem is not siphoning caused by incorrect drain hose settings, restart the washer with the drain hose set down in a bucket on the floor and run a test cycle.
If that does not fix the problem, disconnect power again and check the drain filter housing connected to the drain pump. The drain filter is accessible from the bottom front, it should be located behind a trim panel. There is a protection cap that is removed rotating anticlockwise. Remove the cap and collect water in the drain system.
If still no luck, then the machine must be disassembled and parts must be tested.
Check hoses and inlet valve for internal leaks, check drain pump and pressure switch. Tucked in the control assembly there should be a tech sheet in an envelope with wiring diagrams and diagnostics.
Try first disconnecting power and inspecting the drain system, as explained above.
Regards.
Ginko
Posted on Jun 13, 2011
seeross43
  • 50 Answers
SOURCE: won't spin and does not wash properly
Sounfds like the belt is broken. An easy fix if you are handy.
Posted on May 02, 2012
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Won't spin and does not wash properly
May 02, 2012 | GE Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
GW709 MACHINE SMART DRIVE LOAD 7.5
hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Aug 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
