Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Gas leaking from carb on Briggs and Stratton engine
I have a Briggs and Stratton 6 HP Quantum engine on DAPC Excell 2300 PSI pressure washer. Have not used it for 2 or 3 years. When I wanted to use it recently I replaced the oil and spark plug. Added gas and it leaked truely from the carb. I opened the air filter and noticed the gas coming out of the hole from the carb. It drained completely. I cranked the engine and it started with a little smoke and I shut it down immediatley. Brigg's site recommends changing a gasket. How can I make sure it is not water in the carb? After all if there was any water in the carb shouldn't it have spilled when I drained the oil. The oil has to be drained from the oil inlet where the dip stick is by tilting the whole thing on it's side.
What is the bowl that is referred to in some FixYa suggestions. I cleaned car carbs, dismantled engines, replaced cluth plate but am not familiar with 2-cycle engine carb!
Your help will be appreciated.
    President:
  • 583 Answers
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Posted on Jul 25, 2009
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
I have an excell pressure washer vr2500 with a 6.5 hp Briggs and Stratton motor after pouring gas into empty gas tank see gas leaking from carburetor
YOU HAVE A FLOAT IN THE CARBURETOR THAT MAY BE STUCK THERE IS A SMALL NEEDLE VAULE THAT ALSO MAY BE STICKING YOU CAN GET A REBUILT KIT FOR THE CARBURETOR
Feb 23, 2014 | Cam Spray 25006BX 2500 PSI Cold Water Gas...
My 5.5 hp Briggs & Stratton pressure washer won't start and gas leaks out of the air intake after several attempts on trying to start.
sounds like it's flooding . it could be a spark problem it could be that the carb needs to be rebuilt i would check for spark first you could also run a compression test on the engine . also keep in mind some times if your pump is clogged it will not let your engine start and will be hard to turn over .
Oct 27, 2013 | Briggs & Stratton Garden
Briggs and Stratton 3000 psi wont start.
did you leave fuel in it for the 30days and how old was the fuel then it is only good for about 30days in small engines
Jun 03, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Briggs & Stratton 6.5 hp Quantum
The problem that you are describing is caused by intake valve not seating correctly. I see this problem on engines that have many hours of use or lack of service. You may be able to grind /reseat /adjust valves but usually requires new guide, valve and spring. Enjoy
Oct 03, 2008 | Garden
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
2,035 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
