Question about Kitchen Appliances - Others
Heat control unit for Renaware oil core fry pan. Has E19762 and 94 20 on base. Unit has Cat No..P182-74 on rear. Anything else fit this please?
artbesio
  • 55 Answers
SOURCE: 2000 Chevy Tracker 2.0 pouring oil
leaking from top or bottom? tr checking around the valve covers. if there is a build up you may need to change your valve cover gaskets. if you can let me know where the oil is collecting i may be able to advise a bit better.
Posted on Mar 09, 2009
  • 336 Answers
SOURCE: 2000 silverado changed oil pan gasket rear main
Ouch. A main, rod, or cam bearing failure will cause these symptoms. Did this happen before or after this work was performed?
Posted on Jun 10, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: My cat chewed the wire
If the damage is minor, you can cut out the chewed-up part of the cord and splice the remaining parts together. You'll note that the cord is two wires running side-by-side. Separate them for a couple of inches. Strip off a half-inch or so of the insulation from the ends. Twist the bare ends together, from the wall part to the plug, and insulate the connection with electrical tape. Repeat for the other wire. Make sure you keep the polarity correct; one of the wires will have a rib on it or will be marked with a color stripe.
If the cat's made a complete hash of the cord or you don't feel comfortable trying to fix it, Radio Shack sells a good assortment of replacement adapters. You want to find a replacement with the same voltage and current rating as the original and the same size plug to fit the phone base. You might also be able to find a replacement online if you search by your phone's brand and model. Another option is to check thrift stores or resale shops like Goodwill in your area. They often have a lot of these adapters (also called "wall-warts") to pick through, and may have a suitable one. I've been able to find several I've needed at the stores here, and they're usually only a dollar or so.
Of course, the absolute last resort is to replace the phone, but that's no fun.
Radio Shack and big-box home improvement stores like Home Depot sell plastic tubing you can put around wires to gather a bunch of loose ones together and protect against further kitty attack. You might want to invest in some (it's cheap!) to avoid future damage. It's also nice for general neatening of computer or stereo hookups.
Good luck and thanks for using Fixya!
Posted on May 16, 2011
dunnbiker
  • 8546 Answers
SOURCE: Need a heat controller for Leyse electric fry
http://www.hawaii-gourmet-shopping.com/leyseprobe.html $23
Posted on Jun 22, 2011
  • 6 Answers
SOURCE: I need the heat control plug for rena ware frying
Rena Ware Electric Skillets use the same control as West Bend WB-1 . The back of the Rena Ware Control does say WB-1. Mine is 1500 watt.
You can find the WB-1 ebay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.
Posted on Jan 26, 2012
Change oil sending unit 04 tahoe
It is located on rear of engine back by the distributor use to be. see attached pic
Mar 15, 2015 | 2004 Chevrolet Tahoe
I need a new "leg" for my society electric fry pan
You don't need anything unless the frying pan doesn't work because of the leg.
what you can do is just put an object in place of the leg it works out cheaper too
Oct 21, 2013 | Society / Regal Ware Society Regal Ware...
Once the 'condensate tank' is drained the unit will NOT reset....The tank full light stays in and the Unit continues to run the fan, but will not heat ...for HOURS........Help.....I realy did
When our unit was moved with a full condensate pan, the switch lever became lodged in the "full" position and the unit wouldn't heat. This is how I fixed it.
1. Unpug the unit.
2. Remove 8 screws from the housing.
3. Remove the rear housing, swinging the bottom away from the chassis.
4. Remove the front housing similarly, taking care to release the tabs from the vertical chassis rail, and avoid stressing the wire leads to the control panel.
5. The condernsate float and switch are at the right front at the base of the chassis. Assure that the float is free from obstruction and debris in the condensate pan. Assure that the switdh lever is free to travel to the limits.
6. Re-assemble the unit it reverse order.
Apr 21, 2012 | Soleus Heating & Cooling
I'm looking for one skillet power control for Rena Ware fry electric pan Cat. 17530
You can find the WB-1 eBay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.1_26_2012_12_42_14_am.jpg
Sep 07, 2011 | Precise Heat KTES2 Electric Skillet
I don't know if there is a place to drain the air conditioner unit.
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
How to replace a heater core
Heater Core Removal & Installation Front To Remove:
  1. Make sure you have the anti-theft codes for the audio and the navigation system, and then write down the audio presets.
  2. Disconnect the negative cable from the battery.
  3. From under the hood, disconnect the heater valve cable from the heater valve. Turn the heater valve arm to the fully opened position.
  4. When the engine is cool, drain the engine coolant from the radiator.
  5. Disconnect the inlet heater hose and the outlet heater hose from the heater core.
  6. Remove the mounting nut from the heater unit. Take care not to damage or bend the fuel lines, the brake lines, and related parts.
  7. Remove the dashboard.
  8. Remove the evaporator.
  9. Remove the mounting bolts and remove the heater unit. Front heater unit honda-10-00-4128.gif
  10. Remove the self-tapping screws and the clamp.
  11. Carefully pull out the heater core so you don't bend the inlet and outlet pipes.
To Install:
  1. Using care, install the heater core to the heater unit and secure.
  2. Using care, install the heater unit and tighten mounting nuts and bolts to 7 ft-lb (10 Nm).
  3. Install the evaporator.
  4. Install the dashboard.
  5. Connect the inlet heater hose and the outlet heater hose to the heater core.
  6. Connect the heater valve cable to the heater valve.
  7. Refill the cooling system with engine coolant.
  8. Adjust the heater valve cable.
  9. Make sure that there is no coolant leakage.
  10. Make sure that there is no air leakage.
  11. Connect the negative battery cable.
  12. Perform the power window control unit resetting procedure.
  13. Enter the anti-theft codes for the audio and the navigation system, and then enter the audio presets.
Rear To Remove:
NOTE: The rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system) and the rear power transistor (climate control system), the rear air mix control motor (climate control system) , the rear mode control motor and the rear expansion valve can be replaced without removing the rear heater-A/C unit.
  1. Remove the self-tapping screws and the clamp, and then remove the bolts and the rear evaporator lines with the rear expansion valve. If necessary, remove the rear expansion valve. Use a second wrench to hold the other fitting on the valve so the rear evaporator lines won't twist. Leave the first fitting loosely connected so you can use it to hold the valve while you loosen the second fitting.
  2. Remove the rear heater hoses.
  3. If necessary, remove the rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system), the rear power transistor (climate control system), the rear air mix control motor and the rear mode control motor.
  4. Remove the self-tapping screws and the lower housing.
  5. Remove the self-tapping screws, and carefully separate the left upper housing from the right upper housing. Remove the rear heater core.
To Install:
  1. Replace the rear heater core.
  2. Attach the heater hoses.
  3. Make sure no air is leaking from the left upper housing and the right upper housing fitting and from the upper housings and the lower housing fitting.
  4. Before reassembly, make sure that the rear air mix control linkage and door move smoothly without binding.
  5. Before reassembly, make sure that the rear mode control linkage and door move smoothly without binding.
  6. Reassemble the housing.
  7. After reassembly, make sure the rear air mix control motor runs smoothly.
  8. After reassembly, make sure the rear mode control motor runs smoothly.
  9. Refill the cooling system and make sure that there is no coolant leakage.
Oct 16, 2010 | 2005 Honda Pilot
My truck smells like anti-freeze and the left side of the windshield fogs up... the defrost only blows hot air on the passenger side. Ive been told by two shops that I have to replace the heater core... I...
You need to replace the front one, that one sit under the dash, your truck has front and rear a/c and heater, the rear heater core is for the rear unit, that heater core is to give you heat for the rear unit, that heater core sit in the rear of your truck inside on the side, that one don't have anything to do with the front one leaking, order the one for the front unit. hope this was very helpful.
Aug 18, 2010 | Chevrolet TrailBlazer Cars & Trucks
Are there catalytic converters fitted on 406 2.0l
Its a dpf not a cat.Easy way to clean out[regenerate]First bring the engine to normal temp bring up the rpm to 4000 for 2 mins,then allow to idle for 30 seconds then bring the rpm up to 3000 rpm for 3 mins and yourfilter will have regenerated [fancy word for clean itself out. DPF = diesel particulate filter.Its important to use good quality low ash oil for your oil changes.
Mar 03, 2010 | 2005 Peugeot 405
We have no heat or even air coming on in our 1996 plymoth neon there is also water leaking from under the passenger side dash board were the heater core is can you help please thanx
these guys are retarded, could be the fuse, could be the relay, could be the fan control unit, could be the resistor, could be the fan motor itself. if the heater core was leaking, you would still have heat, you would just smell coolant, if it was leaking enough to not have heat you would see it on your floorboard.
Feb 19, 2009 | 1997 Plymouth Neon
My GE 168997 is not heating up enough..
call and complain. possibly ask for a now one
Jan 07, 2008 | GE 168997 Deep Fryer
Kitchen Appliances - Others Logo
42 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
