Question about Garden
John dear d140 haw to attach my deck - Garden
ADJUSTING THE BELT ON JOHN DEERE D140
The belts have automatic adjustment. If is the deck belt make sure the tensioner arm is free and not stuck. The transmission drive belt is also automatic adjusting.
Jun 02, 2017 | John Deere Garden
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
SVC SVC on hours screen. Have 50.2 hrs what service do I need?
Here is a link giving general details about the meter and what the two different SVC's mean. The part about the D140 is near the bottom of the page. There is an attached .xls file link that shows more detail. You should have gotten a maintenance schedule with the tractor. If not, contact the store you purchased it from or your local John Deere dealer. They will assist you in getting all the information you need.
https://groundscare.custhelp.com/app/answers/detail/a_id/117/~/hour-meter-and-service-reminder---100-series-tractors
Dec 07, 2015 | John Deere D140 48 in. 22 HP Hydrostatic...
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
