Question about Garden
How to adjust the fuel mixture screws on GHT 17 WEEDEATER/
trippssmengi
  • 76 Answers
SOURCE: how to adjust fuel mixture screws
Initial settings are 1 1/4 turn out on high needle and 1 to 1 1/4 on low needle. Once its running start with low needle, while at idle slowly turn low needle in till you here idle start to peak and start to drop again then turn back to peak then with throttle lever squeezed adjust high needle the same as low till you hear it peak. Good luck and if any problems or questions feel free to ask.
Posted on Mar 17, 2009
motor1258
  • 6674 Answers
SOURCE: I don't know where the air/fuel mixture screw is on my carb
There should be one screw (I'm assuming it's the Carter YF carburetor 1 barrel) that's by itself away from linkages etc, more to center at base of carb where it meets manifold, that is angled approx 45 degrees going in to base. That should be your mixture screw. What symptoms are you experiencing anyway?
Posted on Apr 04, 2009
SOURCE: looking for the air fuel mixture screws on carb any help?
[IMG]http://i199.photobucket.com/albums/aa59/88gixxer/100_4177.jpg[/IMG]
Posted on Apr 09, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi BC30 Weedeater - Cannot Start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • 3567 Answers
SOURCE: where is the air/fuel mixture screw
A “very helpful” rating for this answer? Thanks!
Posted on Jun 28, 2009
Weedeater will idol but won't run - it will cut off when you try to give it gas
To begin with, let's start with the basics.
  1. Are you using fresh gas? If not, you need to get some. If there is any old gas/oil mixture in the machine, remove it by pouring it into some sort of container.
  2. If want to purchase a gas/oil mixture already mixed, a store like Home Depot or Lowes has quart cans at the correct mixures. 50:1 / 40:1 etc. and it's Leaded gasoline usually 91 octane.
Weedeaters will lose their carburetor adjustment over time because of vibration or the fuel mixtures may change. The carburetor settings are crucial for the machine to run properly.
Not all carburetors are the same, but which ever one you have, you will need a special adjusting tool to do this. You can find adjusting sets locally or here. https://www.amazon.com/HIPA-Carburetor-Adjustment-Including-21-Teeth/dp/B01FAAKN7E/ref=sr_1_3?ie=UTF8&qid=1467833656&sr=8-3&keywords=carburetor+adjusting+tool
Not To do this process, you will need to identify the 2 special
adjusting screws on the top or side of the carburetor.
The screws are highlighted as HI and LO. The HI allows fuel adjustment for the weedeater at full throttle. The LO is for the adjusting the idle.
Try these steps:
1. Adjust both screws clockwise until just seated (tight) using the correct tool (from a set similar to the one above)
2. Rotate the HI screw 1 1/2 turns counter-clockwise
3. Rotate the LO screw 1 turn counter-clockwise
4. Start the machine.
5. When it's running (spitting, coughing...) adjust the LO screw a 1/4 turn either way until you get a smooth idle.
6. Pull handle to run at full throttle. If the engine is sputtering then it's getting too much fuel....adjust the HI 1/4 turn clockwise checking to see if the engine runs smoother.
7. When you get the weedeater running smoothly, there are no further adjustments to be made. Just make sure you are using FRESH gas/oil that hasn't been sitting longer than 30 days.
Good Luck!
Once j
Jul 06, 2016 | Garden
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Weedeater ght 180 wont start
You'll probably need to remove the carb and clean it out. Sounds like the fuel passages may be clogged.
Oct 05, 2012 | Weedeater Gas Powered Hedgetrimmer...
Carberator adjustment on weedeater ght-22 h screw anf L screw
Turn the "L" screw in until lightly seated, then turn out 1 1/2 turns then lightly seat the "H" screw and then turn it our 2 turns.
Apr 16, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Need "L" and "H" setting on carb mixture screws
Lightly seat the screws all the way in....then back them out about 1 and 1/2 turns. From there here is how to do the final Zama diaghragm carburetor adjustments.
http://www.zamacarb.com/tipspage.html
Oct 30, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
Gas weedeater wont start
assuming weedeater brand weed eater, the carb. has a filter screen, that blocks and does not allow the pump to push sufficient fuel. A phillips head screw on the side of the carburettor secures a square plate, remove the screw and plate and gently brush the screen clean, dirt collects on the visible side.
Dirty foam filters if fitted change the fuel mixture and make it too rich to run.
and the fuel mixture knob, although secured by a tension spring, moves and may need to be readjusted
Jul 30, 2008 | Electrical Supplies
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
