Good day. 2 horizontal lines appear on my pensonic tv 1826. how to get rid of these? Thank you
  • 244 Answers
SOURCE: Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Posted on Nov 26, 2007
CrazyLarry
  • 173 Answers
SOURCE: Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Posted on Jan 19, 2008
Cybertech
  • 149 Answers
SOURCE: TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Posted on Apr 01, 2008
issy2
  • 462 Answers
SOURCE: Horizontal lines have appeared on the screen?
Its either because you dropped it some where or its because u charged it with some other charger other than the specified one. There are 2 solutions for it one is leave the ipod unused/untouched without any charge in it for 4 to 5 days. If u still get the line appearing on the 6th day then the only solution is to get it opened n try alligning the screen else replace the screen.
Thankyou
Posted on Jul 31, 2009
shadowarrior
  • 43 Answers
SOURCE: 2 or 3 horizontal lines in my nokia N95 8Gb display
90% chance LCD problem...eventually those lines fill up the screen. Soln: Change the LCD.
10% chance of moisture problem. Dry it out by-
1.take the battery off
2. put it in a bowl of uncooked rice.
3. make sure the phone is covered by it, and let it stay for 5-10 hours.
Rice should absorb the moisture and could solve the problem. If it doesn't soln:1 is the only way out.
Posted on Sep 05, 2009
How do I get rid of horizontal lines
The picture should be free of horizontal lines. If the lines are present on the TV screen, press the SMART button on the remote control and select Settings > SUPPORT > Picture Test. This menu will appear on the test picture. Select which option best describes the result you have.
Aug 21, 2017 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
NEED REMOTE CODE FOR SOYO TV MT-SYKIT32K1AB
Found this on another site, the problem is that SOYO appears to be very dead (which you probably already knew...). Their website is up for sale but I did find this number. call SOYO at: 909-292-2500
Here are three remotes that might control your Soyo TV:
RCA RCRP05B $20?? at Best Buy and Walgreens
OneForAll URC-8820N or 10820N. About $20?? at Sears
These remotes are available on-line also.
Use setup code TV 1826
Good luck with that
Oct 01, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
One horizontal line on TV
Either bad solder connections on the vertical output IC or bad part in that circuit, IC or something else. I presume it is NOT a flat panel set but has a picture tube as no model number is listed.
Dec 15, 2012 | Televison & Video
A multi-color horizontal line appears on screen
yes it sounds like one of the sus boards have gone or a buffer take to tv repair if you have no knowlage on how to repair
Apr 13, 2010 | Vizio L37 Television
Thankyou
Jul 31, 2009 | Apple iPod MA446LL/A MP3 Player
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
