Question about Garden
I have a johndeer 420 and it keeps spitting gas out of the carb, i put new carb on it new points and condencer on it . cant keep it running what would be going on?
I agree with the valve issue. Either the inlet valve clearance needs adjusting or the valve may be leaking. Either way the compression is blowing past the inlet valve seat and out the carb, and the gas with it. Inlet valve should have ara minimum. 004" clearance.
Posted on Apr 29, 2017
  • Garden Master
  • 3,828 Answers
Wont be the carb
if you are sure the carb and pipes ,linkages choke and float etc are correct
could be the inlet exhaust valve clearances
not sucking in the fuel to the combustion chamber
i have a johndeer 420 and it keeps spitting gas ou - 203294-2-hpsofzl4yoq5ipvgh24ehjib-2-0.jpg
Running issues
BASICS, BASICS, BASIC......
**CHECK PLUGS, WIRES, FUEL FILTERS, RUN CAR AT HIGHER RPM AND SPRAY CARB CLEANER DIRECTLY INTO CARB, CHECK (WITH SPRAY CAN OF CARB CLEANER) FOR VACUUM LEAKS BY SPRAYING ALL AROUND INTAKE AREA, VACUUM LINES ETC...
IF IDLE SMOOTHS OUT OR RAISES..CHANCES ARE THERES A VACUUM LEAK
Jul 21, 2013 | 1995 Geo Metro
Weak spark on 1973 yamaha rt3
battery up to parr? try new sparkplug,does this bike have new igniter pac,?check voltage at coil,etc at coil,points..are points grounded?
Jan 18, 2012 | Motorcycles
I have a coleman 6250 generator the carb bowl keeps flooding and it wont start a spring was at the bottom of bowl i have spark and fuel pressure
If it is B&S he spring is to hold up the plastic float housing to keep a tight seal to base of carb. Sits in the center of the bottom of the plastic piece and the bottom of the bowl.
Apr 10, 2011 | Coleman Powermate Premium Plus 6250W...
KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
May 05, 2010 | Mtd 22" Yard Machine Push Mower
I have a jeep that I converted the 2 bbl carb to a single bbl carb and now can't keep it running. Starts great and quickly, idles very smooth and revs up properly for the first 2-3 minutes of running. ...
Sounds like your float height is incorrect in the carb. Hopefully it is a new carb, and not a used one you bought off of someone. Used carbs are not a good idea unless you have the knowledge to rebuild one.
Aug 14, 2009 | 1989 Jeep Wrangler
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Jul 13, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Acts like it aint getting gas
Have you changed the fuel filter.If you have run a temerary feul pipe from the tank to the carb sounds like a fuel restriction,
May 30, 2009 | 1995 Dodge Neon
My 1999 Oldsmobile Alero Gas gauge and fuel system
well # 1 the full gauge when empty is a sign that your fuel pump is bad and that needs to be replaced the part about spitting the gas back out is probrobly a clog between the fuel door and the tank itself or their might be a vapor lock door that might be stuck shut so fuel cant get in im not 100%sure about that but im 100%sure that the fuel guage is the fuel pump being dead.
--THB--
Aug 22, 2008 | 1999 Oldsmobile Alero
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
