Question about Fast Garden
Mower blade will not go fast enouth - Fast Garden
  • Fast Master
  • 3,828 Answers
Belt driven ? rider mower/tractor
would look at -belt tensioner set up - age of belt or slippage
Posted on Apr 29, 2017
Mower blade will not go fast enouth to cut
will need to put that back together because sounds like tensioner /engagement pulley which helps with making the blades turn
Apr 30, 2017 | Fast Garden
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
Lawnmover blades engage when shouldn't
on the linkage to tighten the belt one of them is adjustable look for a rod with a lock nut on it
Aug 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Toro 24038 blade speed governor not working
Not enough torque. Only use 1/2 width of deck on tall grass, go real slow, Ensure side discharge is open! Ensure blade is sharp. Replace spark plug once a year and clean replace air filter. check oil level 30woil.
Aug 10, 2012 | Toro Power Lawn Mower
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Will a honda vertial shaft motor from a power washer fix on a lawn mower
u can make any vertical shaft motor basically fit any deck two things that cause problems are blade hook up and to high/fast rpms check the rpms the power washer might be to fast for it to be used on a small mower deck
Apr 15, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade assembly does not tighten
check out toolpartsdirect.com for parts diagram.
Jun 18, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
23 people viewed this question
Top Fast Garden Experts
roeb
john h
Are you a Fast Garden Expert? Answer questions, earn points and help others
