Air con srk50zma-s powers surge burnt our electronics?
Eu6500is generator trips to red unload when ac is on
Air conditioner compressors require a greater amount of electricity (measured in both volts and amps, but the amps are what is causing the overload). You will need a larger generator to run your AC. You might be able to run a smaller AC unit, but always check the Amps required and compare that to the Amps the circuit breaker on the generator is rated for.
May 30, 2016 | Honda EU6500iS Inverter Generator
No power dead
power outages cause power surges and will damage electronic control boards. I suggest replacing the Control board and checking the interlocking door switches. Whilst inside the microwave check the magnetron for discoloration around the magnetron horn or gun as it were. If it don't look clean and new, otherwise burnt it's bad !
Feb 06, 2014 | Sharp Microwave Ovens
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What is surge absorber? what is the function of
Hello,It is protection from overcurrent to power input (lighting strikes or unreliable electric service to house).Mandatory on computers,hd tv's any sensitive electronics.
Oct 27, 2010 | Mitsubishi MXZ30TN Air Conditioner
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
I had a power surge and now my dryer wont turn on
it could be a burnt off wire(s) at the incoming power terminals,an open thermal fuse on the blower vent housing,an electronic fuse open on the control board
Jul 16, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Screen wont stay on when power button is pushed
Get a surge protector.
More than likely a surge caused it.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 11, 2010 | HP 2009M Monitor
When i turn my air con on and accelerate the car surges. is this something i should be looking into. It doesn't matter too much i'm just wondering if there is some thing wrong with the car. Thanks. the car...
The surge you are feeling is the a/c compressor engaging and dis engaging. the compressor places a demand on the horse power output of the engine which translates into surge feeling.
Jan 23, 2010 | Jeep Cherokee Cars & Trucks
Kelvinator ksr27g won't restart
There is a capacitor that blows from surges it will have an burnt smell to to and may show discoloration. careful it may have a charge in it. does the moter cycle on and off? If so it could be blown. Another thing that helps is if the motor has been trying to start repeatedly it will overheat you will need to turn it off and allow to cool down before restarting.
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
