Question about Mission Audio Players & Recorders
Mission freedom 5 speakers where or what can I replace the mid driver with.
2 Suggested Answers
SOURCE: I bought replacement drivers for Mission 780
Screws are hidden under the plastic plugs where the covers slot in. remove cover, then maybe use a pencil and fingers to prize out the rubber "holes". Once all four removed, unscrew the four screws visible. Carefully lift off baffle, note that tweeter will be attached to the baffle. You then have easy access to the driver, again another four screws holding that in. You may find erosion on the terminals.
Posted on Feb 10, 2011
Where can i buy replacement mid drivers for mission 782
Mission parts available from missionparts@hotmail.com
Dec 06, 2012 | Mission 782 Main / Stereo Speaker
I have this mission 782 for many years! It happen
It's bi-wireable (BUY-wire). Did it occur to you that may be a factor if you're using it that way? The jumpers (or lack thereof) on the back allow or disallow the amp(s) to affect all the drivers. You can tie any amp to one or the other pair of binding posts to test them.
Sep 19, 2011 | Mission 782 Main / Stereo Speaker
Recently one of my mission 782 side bass driver has no sound, is it dead? Do you have any idea where i can get the driver to replace? and is it difficult to replace by myself?
Drivers are easy to replace in most speaker systems. There will be 'spade' type push-on connectors to the drivers. Here are contact details for the Mission service centre in the UK: http://www.mission.co.uk/Distributor.aspx?lang=En&Tab=29 They should be able to supply you with a replacement.
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
Need to Replace the drivers on Mission 782 speakers.
Unless the company that made the speakers machined the allen screws themselfs, I'm sure any standard or metric allen set will work. Just becareful of the bracket because it may be glued to the speaker frame or there might be a gasket between the 2.
There will be a some wires coming from the crossover that will lead to the tweeters and to the woofer. They are terminated with female connectors that will slide on to the male end on the speakers. If the speakers that you are getting are from the same manufacture, then they should have the same fittings. If not, you may have to replace the females to match. It's a simple strip and crimp process.
Just make sure to mark the wires so you know which one is pos and neg. If you mix them it will throw your speakers out of phase and they won't sound right.
Hope this helps.
Mar 24, 2009 | Mission 782 Main / Stereo Speaker
Mission 752F blown driver
I would try ebay first. If not follow this link to see if they can help you out. Mission ltd is located in the uk. http://www.mission.co.uk/
Nov 28, 2008 | Mission MS752F Speaker
Midrange faulty
I've had the same problem/s. A manufacturing fault with the original midrange drivers of all of my Mission 780's and 782 speakers. If you contact Mission through their website they will supply an updated style driver for about £45, I would recommend buying 2 because the other one will fail eventually, if like me you use them every day. All four failed within two years of each other.
Regards
kingar
Aug 04, 2008 | Mission 782 Main / Stereo Speaker
Removing Driver from Sealed Cab
1. Remove the front cover.
2. Remove the four bushes that held it in place. Beneath them are crosshead screws.
3. Remove these screws, and the surround board they hold.
4. You can now see the bass speaker retaining screws. remove them and withdraw the speaker *carefully*. (A knife under the edge helps to get it going.) The wires are at the back mixed up with the damping wool.
5. The tweeter has its retaining screws under the rubber gasket stuck to it.
6. The connectors shoud slide off the lugs, but mine are pretty stiff. Careful with the tweeter's: mine pulled out the termnal completely, and I've had to replace the unit!
Nov 21, 2007 | Mission 780 Main / Stereo Speaker
Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Mar 18, 2007 | Mission 702 Speaker
46 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
