Question about Samsung Televison & Video
Vertical green line that is about 5 inches in from the right edge. How do I get rid of it?
The tv is a samsung 60"...620d model. It is only 1 month out of warranty.
    Top Expert:
  • Samsung Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Apr 29, 2017
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I have a 50 inch Samsung plasma HDTV model LNT4071FXXAA version SS02 it has a small approximately 16th inch vertical line starting at the bottom of the screen and going about 4 or 5 inches up When looking...
Open the back of the tv. Inside you will find a series of connectors with ribbon connectors along the screen edge. look where the line is on the screen and open the ribbon cable clamp closest to the line. Move the ribbon cable a little and re-clamp it. Sometimes a little corrosion creates a bad connection.
Mar 20, 2014 | Televison & Video
Green vertical bars on a Samsung projection
That is a problem with your main board - some of your inputs work fine and another is bogus. The tv input is not working because there could be a defect in your tuner. If you have cable try a different input for the signal.from the box. If you are using OTA, then use an external HD OTA tuner to feed your set.
Sep 09, 2017 | Samsung HLR5067WX 50" Rear Projection HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
