Question about HP Computers & Internet
I have an HP 6200 pro desktop that I am having trouble finding the correct drivers for the 82579LM Gigabit network Ethernet connection. Can you Help?
  • HP Master
  • 3,592 Answers
What you need to know is what operating system does the hp 6200 pro desktop run on ?
from the specs on the hp 6200 pro desktop
it might be
Microsoft Windows 7 Professional 32-bit
Then download the correct driver for the operating system you are using
https://downloadcenter.intel.com/product/47549/Intel-82579-Gigabit-Ethernet-Controller
and then either run the download or point the update driver to the folder the driver is downloaded into .
Depends on the type of driver you download as to whether it installs itself or has to be added via updating the driver and pointing to its location after it copies its extracted files if it is compressed.
Posted on Apr 29, 2017
Intel EXPI931CTBLK Gigabit CT Desktop Adapter Card - PCIe Network Adapter - Cannot find file
Dring boot up go into the bios settings (usually the delete key) and make sure the "use onboard lan" or somthing like that is diabled
Jun 14, 2012 | Intel EXPI931CTBLK Gigabit CT Desktop...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Integrated Intel 82579LM Gigabit Network card 3com Dual Speed Hub 500 package loss
Either you have a bad cable with bad connections at both ends (replace the cable) or the LAN card has failed - replace it.
Jul 05, 2011 | Computers & Internet
Benicia GL8e (Asus IPIBL-LA) motherboard in HP pavilion - need a network driver
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 09, 2011 | Computers & Internet
Where I can find the driver for IBM 10/100/1000Mbps Gigabit Ethernet Low Profile PCI Express Adapter (53Y4005) Network Adapter ?
I just wondering because it should auto detect by your OS but anyway you can use Intel PRO 100/1000 network driver instead.
Mar 11, 2011 | IBM 10/100/1000Mbps Gigabit Ethernet Low...
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
Do I have an ethernet card?
Yes, Intel Pro/1000 is gigabit ethernet, which will do 100Mbps and 10Mbps too.
This will be compatable with your broadband requirements.
Feb 20, 2009 | Dell Ethernet Card Network Adapter
Ethernet controller
More than likely this is the one that you need. It is for a Broadcom NIC. If that one doesn't work, they have this one for a Gigabit NIC listed here. I would start withe the integrated NIC divers. Both files have download instructions on the page if you need it.
Hope this helps. Please remember to rate this information.
Thanks
Jan 05, 2009 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
