Question about Casio Office Equipment & Supplies
Casio Prizm FX CG10 How do I change scientific notation form from xEx to normal scientific notation like x * 10^x
  • 56 Answers
SOURCE: scientific notation
you want to hit mode not menu and then make sure that normal is flashing instead of SCI and hit enter. so just hit mode then enter and it should be normal
Posted on Jan 14, 2008
SOURCE: Reset?!
Thank You so very much, this solution fixed my problem.
Posted on Feb 13, 2009
  • 7993 Answers
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
Posted on Oct 09, 2009
  • 7993 Answers
SOURCE: how do I get a casio fx-115ES out of scientific
Press [SHIFT][MODE][6:FIX]. You are then prompted to enter a number between 0 and 9. The number you enter fixes the number of decimal digits your results will have. If you press 0 all numbers will be rounded. Setting two or three decimal digits should be reasonable for most situations.
Posted on Jan 06, 2010
  • 7993 Answers
SOURCE: Where do i find the
Here is how to set it.
Posted on Aug 23, 2010
My calculator will give me an answer in scientific notation. How do I change it to decimal form?
To switch out of scientific notation, press SHIFT MODE then select Fix or Norm.
Be aware that the calculator will switch to scientific notation anyway if the magnitude of the answer is too large or too small.
Aug 24, 2014 | Casio FX-115ES Scientific Calculator
I have done the calculation using the the shortcut key [x10^X] to enter the exponent,and I got the correct result.
I also did the calculation by explicitly typing the 10^10 factor and I obtained the correct result.
The syntax error may come from your using the minus - sign for subtraction rather that the change sign key (-)
Apr 06, 2012 | Casio FX-115ES Scientific Calculator
How do i convert a number in scientific notation using the calculator?
You can always enter a number in scientific notation. Use the EE or the [x10^X] key to enter the exponent of 10. Whether it will remain in that form depends on the display mode you set the calculator into:SCI, ENG, NORM1, NORM2, FIX.
However if a result is too big or too small, it will always be represented in SCIentific format.
Sep 09, 2011 | Casio FX-300MS Calculator
How do I change from having the answers displayed in scientific notation to normal number display?
You can set your display mode to FIX or NORMAL ( 1 or 2) if you have them. However if the result is too small ( less then 0.001) or too large the calculator will use the scientific format. Generally if there are not enough display positions to show your result, the calculator uses scientific notation.
Jul 04, 2011 | Casio FX-260 Calculator
How can I get my calculator out of scientific notation mode? It is a casio fx 300ms
Please press the Mode button on your calculator repeatedly till you get the following screen
Fix Sci Norm
1 2 3
Press 3 from your keypad and the screen will change to
Norm 1~2?
Press 1 from your keypad and your calculator will be normal again i.e out of scientific notation mode.
Mar 15, 2011 | Casio FX-300MS Calculator
My calculator is stuck on the scientific setting. How do I change it back to normal setting?
Press SHIFT MODE. You can select either 6 for Fixed-decimal notation or 8 for Normal notation.
Nov 12, 2010 | Casio FX-115ES Scientific Calculator
How do i take off scientic mode just a regualer:
Press SHIFT [SETUP]. You can select FIX for fixed-decimal or NORM for normal display. For FIX the calculator will prompt for the number of digits. NORM gives you two choices: 1 will display numbers of magnitude less than 10E-2 in scientific notation, 2 won't switch to scientific notation until the magnitude drops below 10E-9.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Oct 01, 2009 | Casio FX-260 Calculator
My casio fx-115ES is stuck in scientific notation
The FX-115ES can only handle ten digits. 14! is an eleven-digit number, thus the calculator can only display the first ten digits and a power of ten.
Feb 18, 2009 | Casio FX-115ES Scientific Calculator
Open Questions:
82 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
