Question about Answer Lands Phones
I cannot answer my calls I think it might be on hold how do I get that off?
  • Brett Duxbury
    Brett Duxbury Apr 29, 2017
    Hi Joyce Muller, have you checked all phones in house are not connected.
    The line will time out and you hear a tone on the line rather than the BRRR BRRR dial tone sound .
    You may have to unplug each phone one at a time to isolate the cause .
How do i put a call on on and answer another call?
How to Put First Caller on Hold To Answer a Second Call
? 2:01
https://www.youtube.com/watch?v=HEkLpf33JRk
Apr 6, 2014 - Uploaded by ITJungles
Learn how you can answer another phone call while putting the first call on hold on the Samsung Galaxy S4 ...
how to answer incoming call while already on phone - Android ...
forums.androidcentral.com > HTC Android Phones > HTC One M7
Oct 5, 2013 - 6 posts - ‎5 authors
Dec 15, 2015 | Samsung Cell Phones
Broke the bolt that holds the frame together by the crank
I'm having the same problem..the big silver bolt behind the sprocket?
Oct 14, 2013 | Diamondback Coil EX
How do you answer a call on a BB 7290?
This is the instructions in making callsand answering calls and how to mute a call. Making Calls Input the desired phone number into thekeypad, then press the "Enter" button to initiate the call. Press the"Escape" button on the right side of the device to end the call. Tap"Answer" to answer a call or "Ignore" to reject an incomingcall. If you are on a call, tap "Answer --- Drop Current" to end acurrent call and answer an incoming one or "Answer --- Hold Current"to place the current call on hold and answer the incoming one. Press the"Phone" button to mute a call.
Jan 08, 2011 | RIM BlackBerry 7290
No dial tone and when i call my home phone it it doesnt ring.
Turn off your phone and then remove the battery. Press the power on button of your phone without the battery, just hold it for a few seconds. This will drain static electricity on your phone. After that, place the battery back and then power on your phone. See if it works.
Dec 15, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
When i make a call on my n99i it goes on hold
Hi friend,
I think you can check if you have set the"call holding", that is to say ,when on calling, others should hold a moment.You can just reset it,press the "answer key",then you can go back on calling.
If you have any questions about cell phones,you can visit our website:www.1010store.com
Aug 28, 2009 | Dual Electronics N99i Cellular Phone
Help answering calls during peak call times
Yes you need the PC ASA card and not ASX,
Example: to speak to a live person dial 72 and the zero time out option sends it back to reception and it will place it on hold,
reception would need to activate a programmable button ASA button when experiencing high volume calls,
If nobody picks up it will revert to the reception or zero time out attendant with another greeting depending on what type of avaya voice mail you have?
If you have R5 vs mail or Partner mail and not a PC mail some tricks can be done.
This may not solve your answer and ring delay on day or night mode needs to be looked at.
The reality is you can delay the callers ability to get to a live person for a minute or so if they choose to hang out without a ASA card.
Send them to an unused ex port and assign the port to automated attendant two. Depending on you VM we can have up to 5 AA's and greetings.
The fact is if your receptionist can't place the call on hold with a music on hold greeting that says's Bla Bla Bla and more nice stuff and stay on the line we will be with you shortly then you need to hire a new receptionist.
Aug 08, 2009 | Avaya Lucent Partner 616 Phone
CANNOT TRANSFER FROM LINE 4
It sounds like you need to have your vendor come out and program your phone system to ring on line 4 for whatever phones you think you need access.
as for the hold...seems as if you are choosing the individual hold on the phone and not the system hold. Therefore you can only pick up from the original phone.
May 29, 2009 | Panasonic KX-TS4100B Corded Phone
I have a NorStar M7310 phone -I am on a conf call - how do I mute the line where the other parties cant here
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Dec 04, 2008 | NorStar M7310 Corded Phone
Call problem
Yes, it is like a man who replies after thinking in mind. And a such thing is also matters with a system if some virus intend it to do so. I would like to say it is virus problem. Simply format your phone and MMC. It will work proper.
Jan 06, 2008 | Nokia 6270 Cellular Phone
Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can Conference call You can hold a 3-way conversation (conference call) between your handset, an external caller and another internal handset user. During an external call: 1 Press . The external caller is put ?on-hold?. 2 Press or to select name, number or the handset you want to have a conference call with and press or key. The called handset will ring. 3 When the called handset answers, press to start your conference call. 4 Any handset can press at any time to leave the conference call. It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for. Please repost with any other comments or questions. Please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Uniden DECT1080-2 Phone
Lands Phones Logo
Top Answer Lands Phones Experts
NOEL
NOEL
Are you an Answer Lands Phone Expert? Answer questions, earn points and help others
