Question about Cell Phones
How do I get hold of on my phone? - Cell Phones
How can i format my n5800
on soft formatting:
*#7370# should still reformat the 5800 in the same way it re formats any S60 2nd edition or later phones.
on hard formatting:
try this to your phone. turn off your phone. then follow these instructions.
press and hold the following 4 buttons till the phones restarts completely.
1. hold the green button used to accept calls.
2. hold the * keypad
3. hold the number 3 keypad.
4. hold the power button located at the top of the phone.
press and hold the buttons until the phones starts by itself. it will take some more time to start in this way and remove your memory card and do it.
Nov 04, 2010 | Nokia 5800 XpressMusic Smartphone
Tip
L6i And L7i codes
secrets codes Motorola L6i L7i
hold * 65512890 for reset
hold * 5806 sw version
hold * 487989 NS lock menu
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
hold * 787090 Lock net level
hold * 787292 Lock net level
on Jan 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Need to format again my nokia 3200 phone. can i get the code for reformatting this kind of model? thnx
NOTE: all the phone memory will cleared and your phone will be as good as new.
Nov 04, 2010 | Nokia 3200
I want l6 reset code
hi,
Go To Settings -> Initial Setup -> Master Reset-> Code is 000000
esle try 1234
thank you for using fixya have a nice day:-)
Jul 24, 2010 | Motorola Mobility L6 Cellular Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Hold time on the phone
Press hold twice when putting them on hold.
Aug 04, 2009 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7730-when receiver on hook plays on hold music
walk up to the phone and without touching anything else, press "1".
No music.
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
I have motorola l6 phone i want to restore it but its unlock code
Manually reset for L6 Phone
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
here my little trick!
default code is 1234
press menu until the line show 6 digits and enter 000000
done!
Apr 07, 2009 | Motorola Mobility L6 Cellular Phone
How to format phone memory N95?
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
Jan 13, 2009 | Nokia N73 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
