Question about Refrigerators
I have the beverage cooler AB-1200. It is leaking water out of the bottom. What can I do?
5 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Water leaks under refrigerator and food frezing at bottom level
Would like you to click here=> WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
Then scroll down to the bottom area of the page where it describes a model just like yours, Let me know if this is helpful or ask questions and I will assist you.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com Thanks, Sea Breeze
Posted on Feb 18, 2010
  • 29 Answers
SOURCE: How cold should a Beverage Air Mt 15-54 Cooler get?
Thermostat Set @5, 36 Degrees F
Posted on Aug 27, 2012
  • 50169 Answers
SOURCE: Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Posted on Feb 15, 2016
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Why doesn't the dehumidifier portion work?
HAVE YOU CHECKED FOR ANY OBSTRUCTION IN THE CONNECTION?
Jun 20, 2015 | Beverage-Air DW49 Stainless Steel Beverage...
Standing water in the bottom coolers of my prep table.
The drain is clogged. Check the fitting on bottom of evaporator for a vinyl hose, remove it and using a funnel poor a mixture of baking soda and warm water down it. It will then flow to the heated condensate pan. http://www.beverage-air.com/images/undercounterWorktop/manuals/809-049A.pdf
Aug 23, 2011 | Beverage-Air DP93 Refrigerator
Water is leaking from my Beverage-Air MT27 ?? Had moved it from one location to another. Delivery man laid it down and told me not to plug in for 24 hours. Was fine for 2 days now it is leaking water.
The condensate is supposed to drain from the evaporator down to a pan underneath by the compressor. Is is possible that the tube is not aligned with the pan any more. It is simple to check, remove the compressor compartment cover and inspect the pan and the tube. If the tube is out of place, just reposition it. This is likely the problem you are having. Also make sure the pan is correctly positioned.
May 22, 2011 | Beverage-Air MT27 Beverage Cooler...
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Sep 25, 2009 | Kitchen Appliances - Others
Water
Most likely a bad defrost tmer. Usually located at the bottom, locate this and advance the timer untl it clicks. Another solution is to unplug for 48 hrs with doors open, plug back in check drian line, if it cool down to below 35 its definitely a defrost problem. Ohm the defrost strip heater if good, check terminator (should be closed above 60 degrees). If good, replace defrost timer.
Jun 29, 2008 | Beverage-Air MT45 Beverage Cooler...
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Jun 28, 2008 | True TBB-2 Beverage Cooler
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
