Question about Cameras
My G4 reads SD card full. Card has been formatted.
    Master:
  • 496 Answers
Use the camera to reformat the card. Often the camera manufacturers have a special format and your card will only work when you use it.
Semper Fi,
Z
Posted on Apr 30, 2017
  • reo-v May 01, 2017
    Canon does not use special formats for cards. If anyone does this, how would you use the card to transfer photos to a computer? You couldn't.
Camera says new sd card is full
put it in a computer and see what it reads,it might need formatting .
Jan 25, 2018 | Kodak EasyShare C330 Digital Camera
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Sep 02, 2012 | Nikon D60 Digital Camera
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
Won't read the sd card (says card full) wont let me format the card also
If you have another device that uses SD cards or a SD card reader on one of your computers, try formatting the SD card in one of those and then try using it in the camera that is having trouble with it.
Dec 28, 2010 | Vivitar Cameras
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
New sd cards reads memory full
Try to format the card. If possible, use an external card reader attached to a computer.
Make sure the card is unlocked (with the switch on the side of the card).
Have you managed to have other cards working on the camera?
May 07, 2009 | Kodak EasyShare C330 Digital Camera
Xacti VPC-HD1000 "Problem with SD card" "FORMAT / FULL FORMAT"
This card is not compatible with your camera try another brand!
This should fix ya! ( ( all sd cards may look alike but they are not!)
Dec 14, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Camera insist on memory full, but card is empty
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
Nov 17, 2008 | Cameras
Unformatted sd card in xacti camcorder
I have one sd card HAMA 12 GB and my computer and another computer canoty read my cd card iI have so much photo and video and my computer sad o bytes. Why ? I have photo and video i don't like delete . my cd hama card is 12 gb
Sep 25, 2007 | Video Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
