Question about The Computers & Internet
The pattern says "these 2 rows set position of motif". Then it says work 10 rows more as set. What does "more as set" mean.
Knitting: if I'm slipping the first stitch of each row purl wise, with the yarn in front, should I also slip the first stitch when I bind off?
If you are binding off on a purl row (or at least stitch 2 in the row is a purl), then yes, you should slip the first stitch of the bind off row.
If, however, the bind off row is a knit row (or a least the second stitch in the row is a knit) I would knit the first stitch.
A lot depends on the pattern being worked. Personally, I would try it both ways and see which way looks best with the pattern.
Dec 23, 2017 | Sewing Machines
I don't understand when the pattern says 1st and 2nd rows set pattern Keeping continuity of pattern as set work 32 rows more. it does not look at all like the picture of the blanket I am knitting.
Depends on what the pattern stitch is. What it usually means is that the 2 rows form the pattern. that is, you keep knitting rows one and two until you reach the end. Depends on how many rows you have done already. It's sometimes difficult to see the finished pattern until you have knit a lot of rows. good luck
Sep 05, 2017 | Sewing Machines
What does cast off at the arm hole side on all parts 1x2 stitchhes and 2x1 stitch every second row mean?
Knitting problems - Knitting Paradise
bind off 1x3, 1x2 and 1x1 st, at both edges every 4 rows. ... 6 I would cast off stitches and then 9and 10 just one each (If you do it at both ... Not sure wht they mean by the first part which is why a stitch count would be ... to do the increases that give you that gentle outward curve to the armhole (see ... decrease 2 sts each side Missing: second
Shaping armholes on back piece of my first sweater - How-to ... Jan 6, 2014 - 10 posts - ‎4 authors
When I bind off 2 st 2 times is that bind off 2 stitches together or... ... Instructions say.. starting From knit row ( back piece) ..bind off on both sides in every second row. ... .than on the purl row I do the bind off and purl to end of row .... edge and the armhole/shoulder edge until you've completed all the bind offs. More results from
How-To Thursday: Beautiful Armhole Bind Off - Stitch-N-Smile Mar 26, 2015 - When you reach the armhole, do the first bind off normally. ... row, turn your work and do your bind off normally on the other side. ... Now continue knitting/binding off normally depending on your pattern. Easy, right? And the result is amazing. All you have to remember is to turn your work one row before your ...
Please help me understand these bind-off instructions for shaping ... Sep 5, 2014 - all 9 comments ... "beg of every other row" would mean you are just binding off on one ... off on one side because the pattern directs you to shape every part of the back of the dress separately: one armhole, ... But a row has two edges and doing this to each edge will bind off the 18 stitches you need to lose, ... What does cast off at the arm hole side on all parts 1x2 stitchhes and 2x1...
Jul 03, 2017 | Sewing Machines
What does RS stand for in a pattern (?)
Usually the knit side is the right side, but sometimes the purl side is used for the right side. When this is done it is called reverse St st. When a pattern tells you to work in St st, it means to alternate a knit row with a purl row.
What does RS stand for in pattern Google Search
Dec 03, 2016 |
I can't move the upper stitch pattern selctor to the K position.
not sure if this is any good to you but its all i can find at mo..The machine has a 'hold' in the blank (or red) posiiton. You have to push the selector dial in a little bit then turn it. If it is in the red position it will only turn clockwise...or go to this link... can move the upper stitch pattern selctor to the position Google Search
Oct 24, 2017 | Singer Sewing Machines
Find the pattern of missing numbers
32 25
17 15 10
9 8 7 3
6 3 5 2 1
Apr 12, 2013 | Computers & Internet
How do i lock the screen and unlock it
You can lock the screen of your HTC Hero screen with a draw pattern. Here's where to set the feature in the Android software.
1. From the Home screen, press Menu.
2. Tap Settings.
3. Tap Security.
4. Tap Set unlock pattern.
5. Read the info, then tap Next when ready.
6. See the pattern, then tap Next.
7. Draw the screen unlock pattern with your finger by connecting four or more dots in a row.
8. Tap Continue.
9. Draw the same pattern again.
10. Tap Confirm.
hope this helps
Sep 14, 2011 | HTC Hero Smartphone
SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
