I have purchased a second TV and managed to get Netfliks working on it. However, it has now stopped working on my main TV.
I have a model ledvd1339A I need a new cord plugs in tv and then the wall mine has stopped working must have a short.how do I purchase one
If this is the item you are looking for, it is available from here: http://www.amazon.com/UpBright%C2%AE-Adapter-LEDVD1339A-LEDVD1339A-2-LEDVD1339A2/dp/B00MWI55DU
Feb 03, 2015 | Curtis 13 Ledvd1339a 12 720p Hdtv-ready...
How do I join netfliks. I am a senior, so need some help. I don't know if I join on My TV or can I do it through tis message
Best to call them before you join, they can anwser all your questions. The number is: 1-888-638-3549. Good luck!
Dec 13, 2014 | Cars & Trucks
Power Up Problems
What is the model number?
Apr 23, 2017 | Samsung LN40A530 40 in. LCD TV
Apex tv remote LD220RM just stop working
It might be the IR board on the front panel, or it could be a main board issue. The best thing to do is probably try a new remote first, which you can purchase a generic one at Walmart, punch the tv code into the remote and try it. If that doesn't work, the problem lies with either the IR or main board.
Let me know how it goes
Apr 04, 2011 | Apex Digital LD4088 LCD TV
I have a RCA model 24V511T can I hook up a roku receiver to view Netfliks etc from the internet. I have hooked up the red white yellow connectors to the input ports on the tv set and nothing happens?
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
Jan 07, 2011 | RCA 24V511T 24" TV
My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Jun 03, 2009 | LG 32LB9D TV
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
