Question about Stihl Garden
Sorry i have a stihl 38 cuts out when i pull the trigger,the carburettor is still factory set . if i have to adjust the carburettor,.how best do i do this ?
    Top Expert:
  • Stihl Master
  • 48,384 Answers
Oe screw is for idle and the other is for rpms
hold the throttle at the point it starts to sop and adjust the high speed screw until you can keep increasing the throttle
won't be much off the setting it is now
Posted on Apr 29, 2017
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ... > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Heres the illustrated parts diagram showing the beakdown on the handle and location of the trigger mechanism. If you want the full parts manual, i can send it to you. :)
Apr 20, 2013 | Stihl Garden
easy... if the carb adjustments are still factory set the you just need to replace the muffler screen or also called a spark covers the muffler exit....
Sep 13, 2012 | Stihl FS 85 Weed Eater
How do i set up the carburetor on a sthil ts400
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Feb 24, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Why does my st400 not stay at full speed when i have the trigger pulled up all the way. I just put a new coil on it.
Your problem is eather a dirty filter or the needle valve isnt adjusted properly,or a hole in pump gasket.
Jan 18, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
