Question about Caroma Home
How do you replace a toilet seat on a Caroma bowl where the original seat bolts are within the bowl? No external bolts are visible.
jyackle5
  • 8197 Answers
SOURCE: How do I get the old toilet seat fastener bolts
On top if you look closely you will se that where the hinge is you can lift up a plastic cap and see the top of the screw. From there you can remove screw. It should be a flat head screw.
Good Luck
Posted on Nov 04, 2009
canddplumb
  • 35 Answers
SOURCE: I can't unscrew the bolts on my Kohler 3386 rialto
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Posted on Dec 03, 2009
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
SOURCE: kohler lowboy toilet seat does not have bolts underneath
My wife wanted to replace our Kohler low boy with a self closing seat. We got a Westport whisper close with unlock-able hinges for easy cleaning. I followed the above advice to use brute force to yank out the Kohler bolts. I then used a hacksaw to cut the new plastic seat bolts so that they would not extend past the thickness of the porcelain. I drilled the plastic bolts thru so that a small drywall toggle bolt would fit thru. Use a washer to prevent it from pulling thru, screw on the toggle and cut off excess screw length so it does not bottom out inside the cavity. Insert the assembly in the hole and tighten. Snap on & lock the Westport seat and you are good to go!
Posted on Jul 03, 2010
How do I remove a slow close toilet seat from a Caroma Carvelle one-piece dual flush toilet
All toilet seats are done one of two ways;
A plastic or brass bolt underneath are the rear of the bowl.
A removable cap on the top rear of the seat base.
spec sheet is here
http://www.caromausa.com/database/files/library/Caravelle_Smart_One_Piece_Spec_Sheet_989900.pdf
Caroma website, Installation instructions and Contact details.
Caravelle Smart 270 One Piece Toilet
Dec 13, 2017 | Caroma Home
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Refill water doesnt stopkeeps running
could be that the flapper is not seating properly and lets the toilet tank slowly drain into the bowl..
clean flapper and drain to toilet in tank and verify for proper seating.
if it still runs, my opinion would be to change flapper.. (if new enough, then under warranty)
Aug 02, 2010 | Caroma Home
Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Jan 26, 2010 | Caroma toilet - water saving Sydney Low...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
I need a tank LID for the 270 Caravelle dual flush toilet. Where can I get one fast? A customer broke the lid in a thousand pieces and we need a replacement ASAP.
Toilet seats are standard and fully interchangable. You should be able to pick one up at your local hardware store. The only thing you need to know is if you have a round or elongated bowl.
Sep 18, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Home Logo
41 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
