Question about Sentry Home Security
How do I open my Sentry Safe model 1610. The factory combination does not work and I just replaced batteries.
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Posted on Nov 25, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
  • 42 Answers
SOURCE: sentry safe
You want to be sure not to suffer a "lock out". Now, that'll cost you a few bucks -- probably more than the safe is worth...
I am quite familiar with combination lock safes, and I know that one cannot hurt them by locking them whilst the door is open, and I'd guess that digital ones should not be damaged by locking them open either.
After all, for a large safe that isn't being used, I prefer to lock them open.... no one can get stuck inside one and if I forget the combination, I can get it easily directly from the lock itself.
I'd look for a sensor that is confused. There must be several inputs to the lock that tell it that all is right with the world --- Above all, do not put anything into the safe until you have fixed the problem or decided to 'deep six' the safe.
Regarding the error message. Does the error light blink four times or in some pattern? If there is any pattern to the blinking it could be a message that tells you what is causing the problem.
If all else fails... I'd suggest a locksmith. There is something going on inside that lock that isn't right.
Calling a locksmith may not be cost effective, since he has to make money, and the safe itself isn't all that high qualtiy or expensive to begin with.
Posted on May 13, 2009
  • 80 Answers
SOURCE: Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Posted on Sep 07, 2009
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
Jun 13, 2010 | Sentry Fireproof Safe
I have a sentry safe 1610 that my combination will not open it. Is there anyway to reset the combination or open the safe
Take the safe to a safe specialist in your area. They have a way to open the safe. Because safes are meant to be SAFE - codes are not divulged.
Nov 20, 2009 | Sentry Fireproof Safe
We forgot the combination to our Sentry Fire Safe Model 1610 HELP
Contact SENTRY
Sentry Group
Attn: Dept. 200 882 Linden Avenue
Rochester, NY 14625-2784
Please allow 7-10 business days, upon receipt of your request, to receive your combination.
This request may be faxed to us at : 585-381-2940.
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $15* money order on your fax (please allow 24 hours for processing your faxed request).
To pay by MasterCard or Visa please contact our Customer Service Department at 1-800-828-1438 (please do not fax your credit card number).
Jul 31, 2009 | Sentry Fire-Safe Media File - SEN6720
Lost codes
would you know the factory recovery code for sentry 1610 as
i lost it or it is locked in my safe. My battery has been dead
for some time and I think it lost it's memory.
Jul 17, 2009 | Sentry Fireproof Safe
Sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Mar 29, 2009 | Sentry Fireproof Safe
Oct 09, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
Changing the combination
Apr 24, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Home Security Logo
71 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
