Question about Pool & Spa
My hot tub has an error code of 109 on display. And has stoped running.
2 Suggested Answers
freeski69
  • 12 Answers
SOURCE: no spark, it was running find and sudenly stoped. ??
More than likely it's your ignition control module or cdi/coil pack. It happened to mine years ago. Ypu can test them with a voltmeter for resistance and voltage output. Hope this helps.
Posted on Apr 28, 2016
Testimonial: "thank you......"
What does code ic mean?
I have not seen an ic error code. I have seen ICE several times. So either you do not have the original pack that came with the spa or your display may be malfunctioning.
What is your hot tub doing while the ic code is pressent?
Portable Hot Tubs and Spas On Sale
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
Catalina spam
Hi, Lori Thanks for the question. It sounds as though your tub froze over and tripped the freeze sensor. If the freeze caution is gone and the tub will not rise to temp, either 1 of the heat sensors or heating element has gone bad. With a bad element or sensor you should have an error code on your topside display. At this point I would recommend contacting a Spa Technician, unless you have some spa repair knowledge or feel comfortable attempting a self repair. I hope I was able to help, Thanks again!
Feb 12, 2014 | Pool & Spa
I bought a FreeFlow hot tub from a friend. The pump just continually runs for 15-20 seconds then shuts off. The temperature also is not rising, I can't seem to get it to work properly no matter what I do....
Thanks for your question. A hot tub is one of those items I personally do not recommend purchasing used, unless from a reputable dealer that can provide some type of warranty or service contract. I only say this because it\'s possible for them to have many many problems indiscernible to the naked eye.As for your particular hot tub, are there any error codes on the topside display? when the tub shuts off does it trip the breaker as well? it sounds as though there may be a problem with the circulation pump or possibly one or both of the heat sensors. it could also be the heater itself is not functioning properly and this is causing the system to shut off. Unfortunately, without more information, or looking at the tub I cannot tell you which of these to troubleshoot first. The only other option I can think of is to call a service technician to inspect the tub,a service call runs about $60-$90 per hour, If you could give me the error code(s) readout from the topside we could establish a starting point, otherwise we\'re just flying blind & I don\'t want you to spend money replacing parts that still work. If you can post again with an error code I\'d be glad to go from there, I\'m sorry I couldn\'t help more...
Oct 19, 2013 | Pool & Spa
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go out
Rod
US Parts Center
Jan 08, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hot tub won't get hot
Check your filters and make sure they are clean.
Check to see if the heat indicator light is on when the tub is running.
Make sure the gate valves are open on either side of the pump and control box.
Are there any error codes in the little window on the topside?
Rod Kidman
www.uspartscenter.com
Nov 25, 2012 | Home
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub error code sn
check recirculation pump and heater element
Apr 17, 2012 | Pool & Spa
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Code FL1
hi, this generally means a flow error and shows when the heater is looking to heat but there isn't enough pressure running through the heater tube. in this case the thermal overload sounds like it has tripped in the pump.
Jun 06, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
