Where is the power cord located on the 8000 BTU window unit? wtw08er5
  • 143 Answers
SOURCE: Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Posted on Jul 25, 2008
mp3stud
  • 15 Answers
SOURCE: Power Cord Chew Toy
Any qualified electrician will be able to fix it. It shouldn't take more then 1/2 hour for them do to it, and they can even put on a cable that will protect your dog/the cable from biting through again and possibly getting electrocuted. Overall cost should be less then 50 dollars. Check the Yellowpages if you don't know an electrician.
Posted on Jun 05, 2009
  • 340 Answers
SOURCE: I NEED TO REPLACE A POWER CORD TO MY SMALL AC UNIT
A hardware store will have what you need to repair. Tom
Posted on Jun 18, 2009
2rns4u
  • 22 Answers
SOURCE: Have an 8000 btu unit missing the vent hose
Home Depot carries alot of A/C parts that may work for you. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
SOURCE: New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Posted on Oct 09, 2009
Testimonial: "My a/c is still under warranty so LG drilled a small hole in corner of the drain pan on the side where the water was spraying out. Works great now!"
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
Freezing up 8000 btu window unit
Coils may be dirty, filter may be dirty, water not draining or low on freon.
Jul 25, 2010 | Whirlpool Electronic Window Air...
Thank you. I have an 11 year old Kenmore 8000 BTU window unit that has served me well. I am remodeling my apartment now and would like to have a service and maintenance check on this unit that might...
take it to a hvac shop and tell them what you want! or just telll an electrical shop what you want in the cord length---to straighten out the fins n the front coils with a fin coil brush at a hvac supply house,and remove the top/ side cover and fully clean the inside unit, drain lines--both front and back coils---on both sidesan oil the fan motor....TYVM!
Dec 03, 2009 | Kenmore 8000 BTU Single Room Air...
Jun 18, 2009 | Whirlpool Electronic Window Air...
Noise
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
New home 8000 memory craft embroidery machine
Locate a Janome dealer and have him order them for you. The power cord can be purchased from Radio Shack if the dealer doesn't have one.
sewman7
Jul 19, 2008 | Janome Memory Craft 9000 Computerized...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
