Where is the power cord located on the 8000 btu unit?
  • 143 Answers
SOURCE: Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Posted on Jul 25, 2008
mp3stud
  • 15 Answers
SOURCE: Power Cord Chew Toy
Any qualified electrician will be able to fix it. It shouldn't take more then 1/2 hour for them do to it, and they can even put on a cable that will protect your dog/the cable from biting through again and possibly getting electrocuted. Overall cost should be less then 50 dollars. Check the Yellowpages if you don't know an electrician.
Posted on Jun 05, 2009
  • 340 Answers
SOURCE: I NEED TO REPLACE A POWER CORD TO MY SMALL AC UNIT
A hardware store will have what you need to repair. Tom
Posted on Jun 18, 2009
2rns4u
  • 22 Answers
SOURCE: Have an 8000 btu unit missing the vent hose
Home Depot carries alot of A/C parts that may work for you. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
SOURCE: New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Posted on Oct 09, 2009
Testimonial: "My a/c is still under warranty so LG drilled a small hole in corner of the drain pan on the side where the water was spraying out. Works great now!"
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Why is it not blowing air
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
May 14, 2014 | Haier Commercial Cool 12,000 BTU...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Where can I buy this model???
THis one is an 8000 btu unit the one in the link is a 10000 btu unit which will do a better job. http://www.a14electronics.com/product-p/FRRZQ10C10.htm
May 02, 2011 | Friedrich ZStar ZQ08A10A Air Conditioner
Thank you. I have an 11 year old Kenmore 8000 BTU window unit that has served me well. I am remodeling my apartment now and would like to have a service and maintenance check on this unit that might...
take it to a hvac shop and tell them what you want! or just telll an electrical shop what you want in the cord length---to straighten out the fins n the front coils with a fin coil brush at a hvac supply house,and remove the top/ side cover and fully clean the inside unit, drain lines--both front and back coils---on both sidesan oil the fan motor....TYVM!
Dec 03, 2009 | Kenmore 8000 BTU Single Room Air...
Jul 22, 2009 | Danby DPAC8020 Air Conditioner
Noise
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
New home 8000 memory craft embroidery machine
Locate a Janome dealer and have him order them for you. The power cord can be purchased from Radio Shack if the dealer doesn't have one.
sewman7
Jul 19, 2008 | Janome Memory Craft 9000 Computerized...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
