How do I replace a lid that's split - Washing Machines
    Top Expert:
  • 12,826 Answers
Order one
Posted on Apr 29, 2017
How do i get free replacementlids
if they are from a supermarket , reject shop , lids will not be available
best use the container as a planter and get new units
Jul 14, 2016 | Home
Won't wash and won't drain but it does put water in
The lid switch most likely needs to be replaced
Try to use something wood or plastic to push into hole where tab on door goes in on that type they tend to break or split apart
Mar 09, 2015 | Washing Machines
Liner in slow cooker has a crack
Get it replaced, do not use it. I did and mine split and sprayed all over the kitchen. To get a new one is easy. Believe or not, go to your local Goodwill Store! They have tons of crocks and the lids and the cookers separate frm each other that have been donated becase one of the pieces was broken and they donated the rest of the pieces. Lids and crocks typically range from $1.99 to $5.99 and you benefit your community at the same time.
Sep 17, 2010 | Oster Crock Pots & Slow Cookers
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
My screen is faded kind of like the backlight is out
Yes I can. Sounds like a laptop or flat panel display. Both have a small florescent bulb in them that backlights the screen.
If you can order the bulb the bulb is easy to replace.
Laptop/Monitor: Split the plastic case around the lid/monitor (if there are screws you will need to remove them - check under the rubber pads on the inside of the lid as they often hide screws underneath.)
Run a small knife or flat screw driver around the seam and the two halves will split apart. Once you have done so you can easily access the bulb - replace it - reassembly is reverse of dis assembly.
Feb 06, 2009 | HP 98785A 16" Monitor
Need west bend lid 84396 replacement
I need a replacement lid or just handle for 84369 crock pot.
Jul 06, 2008 | West Bend 84596 6-Quart Slow Cooker
Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Oct 05, 2007 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
