Question about Garden
How do i adjust the throttle as my sthil weed eater stallswhen i pull the trigger? thankyou Gavin.NZ.
  • 3 Answers
SOURCE: Ryobi string trimmer -weed eater pull cord hangs out wont start
What model number is your Ryobi?
Posted on Jul 25, 2008
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Posted on Jul 26, 2009
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
  • 403 Answers
SOURCE: My craftsman SimPull 32cc weed
are you switching it from choke, to run ?
Posted on Apr 16, 2011
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    THE FS 46C WEEDEATER WILL IDLE JUST FINE, BUT WILL NOT REV UP WHEN PULLING ON THE TRIGGER. THE THROTTLE CABLE IS NOT DISCONNECTED AND THE CARB IS CLEAN. ANY SUGGESTIONS?
    easy... if the carb adjustments are still factory set the you just need to replace the muffler screen or also called a spark arrester.it covers the muffler exit....
    Sep 13, 2012 | Stihl FS 85 Weed Eater
    Bought new poulan pro PP125e weed-eater and it has an accelration problem. Manual says may need carburator adjustment. Do you know how to adjust?
    new --under warranty -- take it in for a warranty service and adjustment
    they will know how to adjust it as well as will have the correct tools for the job
    Jul 26, 2017 | Garden
    When i start my husqvarna weed eater it has no throttle response...what can cause the problem
    A clogged fuel system or a carburetor in bad need of a rebuild can cause this. Also, if the engine end of the throttle cable has pulled out of the lever on the carburetor, or off of the trigger on the handle, you will have this symptom.
    Jan 30, 2011 | Husqvarna 28cc Gas Line Trimmer
    Sthil weed eater will not run when hot?
    you will need to replace you muffler so the machine can get rid of it's exhaust
    Jul 23, 2009 | Garden
    Poulan Pro weed eater won't accelerate.
    check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
    Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Garden Logo
    29 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
