Question about Garden
Hydrostatic drive stops working after a few minutes of operation
2 Suggested Answers
  • 200 Answers
SOURCE: hydrostatic drive not working
The drive belt probably needs replacing.
Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
Husqvarna 2548 trans axle stop moving after short time of moving i let it sit for short time moves again then stops again any common problems i should check/
check for oil level in the drive. There may be a problem in the drive pump or drive motors/ gearbox. If this is a mower with a hydrostatic drive then it may be the hydrostatic drive as they do fail on a regular basis.
Aug 30, 2014 | Cars & Trucks
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
My johnb deere L120 engine runs fine, but after about 20 minutes the tractor slowly stops moving, i dont know if this is a drive belt problem or something wrong with the hydrostatic?
Hi, most likely the hydrostatic is over heating. Remove the battery and battery carrier. From here clean any grass and debris from the hydro and cooling fins, also check the cooling fan condition. Under the mower check the idler pulley on the hydro drive belt is travelling freely. Hope this helps, regards Phil.
May 08, 2011 | John Deere Garden
Hydrostatic drive not working
Jul 18, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 275 GT garden tractor with hydrostatic trans mission the fluid got low an would not move I bought fluid from dealership an installed fluid moved back an forth went to check level would not move is...
If the fluid was low and the mower stopped moving the hydrostatic will most likely need rebuilding or replacing. If it only started slipping changing fluid migh have saved it. You can jack up the rear with the tires off the ground and let it run in gear for a few minutes then do the same in reverse. Do this several times if it can be saved it will start pulling slowly when it does make sure it is still full of fluid let it down and drive it or mow with it. It could just be an air lock in the trans.
Aug 16, 2009 | John Deere Garden
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Transmission stops pulling when it gets hot
when was the last time you had the trans serviced?
It could be seizing up from the lack of oil
May 09, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
