Need value of c557 on panasonic pt61hx40b - cap is toasted :(
  • 1 more comment
  • jeff_carlin Jul 25, 2009
    If I search the panasonic parts site, I only find ECJ2VC1H102J CAP,C .001UF-J-50V for the pt-61hx40b.
    I do not see the ECKD3D102JB .001UF-J-2kv you posted.
  • 10,515 Answers
C557 ECKD3D102JB CAP,C .001UF-J-2KV TNPH0366 BOARD
C557 ECWH16392JVY CAP,P 3900PF-J-1.5KV OTHER BOARD
Thanks!!
Posted on Jul 25, 2009
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
Burning smell
Need the board locations of the parts your needing the info on. Such as cxxx or Rxxx stamped on the PC Board.
Mar 05, 2008 | Zenith H27F36DT 27" TV
Vertical hold on my panasonic tv is slightley out
no have adjust.check for change resistor value or cap.
Apr 02, 2010 | Panasonic Televison & Video
Bad capacitor.
You can replace them with higher value capacitance and voltage but not lower. I use good caps made by PANASONIC FM or FC series (105c Low ESR, high ripple current) from DIGIKEY.
Feb 02, 2010 | Samsung 732N 17" Monitor
Panasonic pt-47wx53 C509
As you look from the back of the set (with the cover off) it is on the far right large board, C509 is the location number--it will be printed on top of the board under the cap.
It is about 2 o'clock near a large plug--on right side of right board--the one with the large gray transformer with a large red wire--part is forward of that transformer and red looking in color--two leads---it will have the C509 printed on top of the board under it.
This is a common failure part is this set--some will have a physical crack in the red part and others will look perfect-----value with a cap checker is .47 UF----200v is the working voltage --as long as you replace it with a cap of at least 200 volts of the same value--it will be fine--
There are two ways to get at it--pull the large board it is on OUT--I do not recommend this----or pull the whole light box out---very easy and safe---if you locate the cap and want to know how to pull the light box out let me know--
If this has helped you rate this solution as I do this here for free.
SD TECH
Jan 05, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I need the capacitor value and replacement part number for C557 on board tnph0366 for panasonic pt61hx40b
well u can always go up on voltag but not dowm exe 50uf 25v this will work any voltag above 25v exmple answer 50uf 35v ur better u can get an idea of voltage the value is by +volt of surrounding caps also take multi meter read +voltag rember the formula i gave u hopes this helps you
Jul 25, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Need value of c557, burnt beyond recognition, can you help?
May 29, 2008 | Panasonic PT-51HX40 51" Rear Projection...
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
Help on value of surge R801 Panasonic CT27SX11E Please
Check this out. http://www.pasc.panasonic.com/Epartr/PartsList.asp
Oct 31, 2006 | Panasonic CT-32D12D 32" TV
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
Electro Med Services...
