Question about Refrigerators
Ice0400HW2 has slow ice production how do i fix this?
I have a Frigidaire FRT21S6A top freezer. the ice maker is dispensing ice cubes, but incredibly slowly. what is causing this and can it be fixed without replacement?
I appreciate your post, friend!
I understand that your icemaker is dispensing ice cubes at a slow pace inside of your Frigidaire refrigerator. You could have a slow ice production due to your water filter or water valve. I would suggest checking to make sure your house supply is fully opened and check to make sure your filter does not need to be replaced. This could also be an issue with your water valve. Since it could be anyone of these underlying issues I would recommend contacting a professional technician for proper diagnosis and repair. This will also help you to avoid any unnecessary part purchases. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
Slow ice production
that could be one solution. I would look at how long the freeze cycle is lasting. The machine could be cycling off and on via bin stat. Average cycles from start of freeze cycle to start of freeze cycle is usually around 25 minutes or so. If it is taking longer than that, you may have to dig deeper. let me know. Don't overlook a leaking water valve.
Aug 23, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How to make ice faster
Good day,
When an ice maker harvests a batch, the next batch will be determined by a thermostat embedded in the ice maker body.
When it resets the next harvest will occur, thus determining the frequency of harvest cycles. Thus production.
The first thing to determine is the size of the cubes. If they have become slowly undersized, it could be the water valve's diaphragm starting to swell. If that is the case, then replacing the valve is the only solution. It cannot be serviced.
The second thing is the water feed from the house. The line, and even more so the fittings can start to corrode, slowing the water flow down, producing the same effect described above.
If it has a water filter, that as well can cause this same issue.
Lastly, the temperature of the freezer has a major effect on production. You should check the freezer temperature with an accurate thermometer. It should be at, or very close to zero.
Any temperature above that will slow production.
Although rare, the thermostat in the ice maker can go out of calibration causing slow cycles. Impossible to test, it is one of your last options.
I am assuming the water pressure in the house is normal. Houses with low water pressure can have severe low ice production.
Sep 18, 2010 | Sub-Zero Bottom Freezer Refrigerator
Fridgedaire side by side very slow ice production bin emptied due to ice use after surgery sinc eSunday very litle ice temp turned up yesterday arm down and water filter fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Refrigerators
Ice maker works slow
Usually , slow ice production , is caused by dirty condensor coils ( the coils under the front of the refrig , behind the kick plate ) . Only vacuum what you can see , no need to pull refrig out and all that . It does need to be 3 " from the wall though .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
Water and ice despencer
Production of ice cubes depends on freezer temperature. zero degrees turns out ice more often than 15-20 degrees. Slow water?
You may have a partial clog in the supply line to the water sloenoid vavle. Are the ice cubes normal size when dumped?
Jun 20, 2009 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Samsung RF267AABP Noise problem
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Mar 06, 2009 | Samsung RM255LASH Side by Side...
Unit stop producing ice
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
FrigidAire Side By Side Slow IceMaker
there is no way to speed up the ice production, factory set only way to produse mor os depending on age of refig might have an "extra ice" button on display. even thats atemporary fix and probly speed up by 20--30 min
Jan 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
