Question about Universal iHomeaudio iH6 Docking Station, Remote Control for Apple iPod
On my iHome the screen says AUX and i don't know what that means. When it says AUX my iPod won't play. How do i get that off?
IHome won't play Ipad it charges but says the accessory is not supported by ipad
the best iPad accessories Best iPad Accessories July 2017 The Gadget Flow you can get are on Gadget Flow especially for home kit compatible that you are looking for.
Feb 09, 2013 | iHome Clock Clock Radio for iPhone iPod...
My iPod has a bigger case so not I won't fit on my ihome I only use my ihome for music but my iPod won't fit so I bought an aux cable for my IPod, wene I plugged it in it didn't work the cable worked
Your video ran out. Anyway, you could try using an adaptor so your iPod will sit on your music box. If that fails, connect via your aux lead, gently pull your aux lead out of the back of the box gently and slowly giving it a wiggle, you might make the connection. Other than this, as you've not provide enough footage, you might need to buy a new aux cable that fits. Not all products are compatible with iDevices, you should check the instructions to see if your model of iPod is compatible.
Oct 14, 2012 | Audio Players & Recorders
I bought I Home keyboard IH-K231MS today and I don't have a MAC will it work with HP computer or any other computer ?.
Don't know for sure, but the special keys need a driver you have to install (which is written for an Apple machie, so probably won't work. The normal key may work, but you might have to ID the keyboard. If you can connect an iPod to a PC via a USB cable to sync it (have never used a pc so don't know if that's possible), the PC may be able to see the iPod.
All in all, maybe.
Jan 12, 2011 | iHome iConnect Media Keyboard With iPod...
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Ihome ih9 wont work with 3rd generation ipod nano
Look at the Box and the Manual! 3rd Generation is not supported by iH9! Clearly marked on the Manual.
Jan 03, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Universal iHomeaudio iH6 Docking Station, Remote Control for Apple iPod  Logo
129 people viewed this question
Top Universal Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
 Grubhead
Grubhead
richie46
Are you an Universal Audio Player and Recorder Expert? Answer questions, earn points and help others
