We hooked up my laptop to our maxent plasma monitor/TV. It was working fine. I left for a short amount of time and when i returned, i lost picture. We have since discovered that we are able to get sound, but no picture.
  • 2 more comments
  • charles189 Jul 25, 2009
    as instructed, i turned off the monitor and waited for a good while before turning back on. There is still no picture.
    When the cable box is turned on, we can hear audio - but there is still no picture. Part of the problem is we can not know what input we are on (besides from cable-AV1 because of sound) as there is no picture.
    My guess is that when my computer went to "hibernate" it put the picture to "sleep" as well. This is only my educated guess.
    Again, i want to be clear that it was working fine. We had the picture on the laptop and on the monitor (50" plasma Maxent HDTV monitor). I left the room for a while and upon my return we had lost picture to the monitor.
    Is there perhaps a setting that I need to adjust on my laptop? Please advise...
    Charles
    Comments:
    Jul 25, 2009 - as instructed, i turned off the monitor and waited for a good while before turning back on. There is still no picture.
    Charles
    it does not appear to have done anything...
    you should state your operating system,vista has got some advance option when using external monitor.You should normally restart the pc while the tv is on and waiting for signal from pc.When it loads into bios you should get the display on your tv.Remember to make sure to enable pc input on tv and restart pc while tv is waiting for signal.This should solve this problem.
    Operating system is XP
    how do you enable pc input on tv?
  • 339 Answers
Try the FN-F4 key combo on your laptop. If this works then you'll need to poke around in your display settings and try to figure out what is causing the behavior and change it or simply live with hitting FN-F4 after it goes to sleep. Most likely, the TV is not responding quickly enough to the PC when it wakes up and it assumes that the external display is gone and goes back to internal. You could also lock your setting in to "mirror" and this would likely eliminate the problem.
If the above does not help, please let me know what type of cables are being used to connect the TV and laptop. This could be very useful information in troubleshooting the problem.
Posted on Jul 25, 2009
    Genius:
  • 1,341 Answers
You should state your operating system,vista has got some advance option when using external monitor.You should normally restart the pc while the tv is on and waiting for signal from pc.When it loads into bios you should get the display on your tv.Remember to make sure to enable pc input on tv and restart pc while tv is waiting for signal.This should solve this problem.
    President:
  • 2,559 Answers
With the laptop still hooked to the tv,Hit the FN + F7 key to turn off the presentation mode and then The FN+F5 to change from the laptop display to the TV
Let me know if this helped.
  • 10,865 Answers
Hello. I can help you. First of all turn off the tv and the laptop. After two minutes turn on the monitor and the computer. Check on the tv, using the input button to be sure that you are designating the proper input connectioin for the computer. You should now be back up and running.
I how a 42 in maxent monitor. How do I hook up tv tuner?
the tuner or a set top box etc would have to be connected to one of the sets of audio/video inputs and that input selected.
Jul 17, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Jun 03, 2011 | Maxent MX42X3 42 in. HD-Ready Plasma...
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
I WOULD LIKE TO KNOW IF THERE IS AN UNIVERSAL REMOTE THAT WORKS WITH MAXENT ML3251 HLT LCD TV
i have a 42" MAXENT PLASMA TV & I LOST THE REMOTE CONTROL. MY BROTHER BOUGHT AN ALL IN ONE UNIVERSAL REMOTE CONTROL & SENT IT OUT TO GET PROGRAM. THE CODE IS 1755, & I HAVE ACCESS TO PRETTY MUCH EVERYTHING BUT CHANGING THE INPUT WHILE IN PICTURE & PICTURE MODE
May 30, 2010 | Televison & Video
We hooked up my laptop to our maxent plasma monitor/TV. It was working fine. I left for a short amount of time and when i returned, i lost picture. We have since discovered that we are able to get sound,...
u my have put the tv in shut down mode get your book that came with the tv and look for instrue on that tip always keep your plasms in the coolest spot in the room you wnnt them to stay cool heat stressess the gasses never hook up vides games to your tv also u only get about 3000 hrs before it needs expxnerxrepair hope this helps
Jul 25, 2009 | Televison & Video
I hooked up my laptop to my maxent plasma monitor/tv. It was working fine, but now I have lost picture. I can get sound but no picture
try the F4 or F5key, it will have a picture that looks like a monitor:
you might also have to hold down the Fn key on the bottom row of keys
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
