Question about Mustang Garden
What would make the left transmission on an RZT 50 MUSTANG to stop pulling?
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Posted on Jul 07, 2010
  • 6468 Answers
SOURCE: How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
Posted on May 24, 2012
BAMOUT
  • 2478 Answers
SOURCE: My cub cadet RZT 22, will not turn left or go straight ( the left handle does nothing). I was told its the transmission, is there an alternative problem? As it runs well otherwise, starts good, this
Your seering linkage needs adjusted. I try is first.
Find a free service manual to show you how.
Posted on Sep 01, 2012
  • 6468 Answers
SOURCE: How do you change the transmission drive belt on cub cadet RZT 50 mower
remove the mower deck
Posted on Oct 02, 2012
Hydrostat trans on leftside stop pulling
each side has it's own hydro motor check the linkage first
Jul 07, 2012 | Mustang Rzt 50" Zero Turn Riding Lawn...
May 23, 2012 | Garden
When I pull the PTO lever up, it does not engage the blades.
you will need to check and see if the voltage is getting to the pto itself if it is then the pto needs replaced if not then the switch is bad
Apr 17, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Leaking oil from left transaxle around sproket
This sounds like you have an oil seal problem. Change the oil seal. Good luck.
Dec 14, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Why is my troy-bilt mustang 50 zero turn lawn tractor is smoking and burning oil?
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
Aug 04, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
How do you reset the change oil light on my RZT 50 mower
It turns off by itself after 2 running hours.From 50-52, 100-102, 150-152, etc...
Mar 14, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
I HAVE A RZT TROYBILT 50'' ZERO TURN ONLY 13HRS..THE RIGHT REAR WONT MOVE..
Your machine has a warranty on it and in many cases if you attempt any unauthorized repairs, it will void your warranty.
My best advice it to first contact your dealer or an authorized service center regarding the problem and what you can do yourself without voiding the warranty
Oct 31, 2009 | Mustang Rzt 50" Zero Turn Riding Lawn...
Flywheel not ingaging when turning ignition for my tractor mower rzt 50 kawasaki fr651v
You have a fiber gear on your starter it has striped out,you have to remove your starter to replace it, on some you have to remove the flywheel.hope this help you
Aug 28, 2009 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
29 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Paul Sikkema
Paul Sikkema
Are you a Mustang Garden Expert? Answer questions, earn points and help others
