Question about The Computers & Internet
How do I make my sim work on a pro line tablet L10A1g.And enable pre installed apps that are disabled
The disable button is greyed out
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
sriramoju
  • 171 Answers
SOURCE: How to re-enable VGA display it was disabled accidently
in bios settings there is a option enable or disable onboard display card check , one more option is there press F8 key when you are restarting the system some options is come their select enable vga mode
Posted on Mar 11, 2008
SOURCE: Wireless Button Disabled
After one month of trying everything, I finally figured this one out.  First turn off and restart your computer.  Then press F10 to enter the System BIOS Settings.  Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES.  Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES.  This should restore the wireless LAN button to its original factory settings.  Once you restart the computer the button will be listed as disabled, but press on the button and it should work again.  I hope this helps someone else out!
Posted on Oct 25, 2008
Kancept
  • 45 Answers
SOURCE: volume disabled on macbook pro , can see icon but greyed out
Have you tried resetting the PRAM? If so, the sound board may be bad (side module).
Posted on May 02, 2009
SOURCE: safety lock enabled
if safety lock enabled then some options are disabled.
Simply stop moving (stop driving) and all options will come back!!!
and go to Preferences and select Heart icon and select "Disable safety lock"
Posted on May 13, 2009
How do i eliminate all the android apps on my balaxy tablet that are taking all y storage space? I have no idea where they came from. Thank you.
You need to run the "applications manager".
If you open the icon labeled "Apps", "setting should be in there on one of the pages.
Once you are in "Settings", scroll down to the "phone" section.
There you will find "Applications", open "Applications".
The top of the list should be the "Applications manager".
You will see a list of "All apps", Some of them came pre- installed on your Galaxy Tab, and can't be deleted. But they can be forced to stop and disabled.
Apps that you have installed that you want to delete can be
"Uninstalled".
Apr 05, 2017 | Samsung Galaxy Tab Tablet PC
My ideapad says the process com.google.process.gapps has stopped. How do I fix this?
1. Go to MENU
2. Go to SETTINGS
3. Go to APPS
4. Look for DOWNLOAD MANAGER under ALL
5. Disable it then enable it
Menu-> Settings-> Apps-> All-> Download Manager (Disable then enable)
Or you can try: settings ----> application manager ----> all ----> click the bottom left touch button and select reset apps (this will not erase the apps) this will only restore the apps into its fixed state
Mar 07, 2015 | Tablets & eReaders
How do you retrieve a disable app on Samsung ipad
go to setting than app manager you will find the app their.
Feb 06, 2015 | Samsung Galaxy Tab Tablet PC
How to Delete samples frm samsung galaxy tab 3
if by samples you mean apps you dont want, go to settings, more, application manager, slide to all, look down list to app you want to delete and select it. If you want to remove it hit the disable button and OK to anything following. This disables the app and it wont appear or work until enabled. You cant fully delete anything without root access which basically allows you to do anything including screw up your device, so its not normally provided.
Aug 27, 2014 | Samsung Galaxy Tab Tablet PC
WIll not update or download apps for google play
You just need to disable and then enable the Download Manager applicationby going to settings -- apps -- all -- Download Manager -- and in there you will have the option to disable and after that you can enable the application.
Let me know if that help. :D
Jun 29, 2014 | Motorola Mobility DROID XYBOARD 8.2 MZ609...
Error message-the processcom.google.process.gapps has stopped
Just follow these easy steps:
1. Go to MENU
2. Go to SETTINGS
3. Go to APPS
That should do the trick.
If for some reason that doesnt work, try clearing your app cache, or deleting some recently downloaded apps.
How to fix the process com google process gapps has stopped error mdash...
Apr 21, 2014 | Kocaso M1050
Any way to turn off touchpad when typing ,etc
« Free Up Windows 7 RAM - Memory Cleaner Enable Administrator Account In Windows 7 » Auto Disable Mouse Touchpad When Typing By Nakodari on Nov 25 2009 28 Comments
It is a common annoyances with netbooks and laptops which lack the disable touchpad button. Most blogs out there are covering a single method to disable the touchpad, i.e, go to Control Panel > Mouse Properties and then disable the touchpad from there.
The above method is not suitable for those who need to disable the touchpad frequently for short periods of time. Who in his/her right mind would navigate back and forth just to enable/disable touchpad? This could be quite a hectic process.
TouchFreeze is a brilliant little app that solves this problem. It disables the touchpad temporarily the moment a keystroke is pressed. In layman's term, it disables the touchpad automatically when you are typing and enables it back when the typing is stopped.
It will sit silently in the system tray without disturbing any of your work. Just start typing and don't worry about the touchpad any more.
touchfreeze.pngI prefer using this app even though my notebook has a disable touchpad button. Please note that this app might not work with certain laptops, but should work with most netbooks and laptops that lack the disable touchpad button.
Download TouchFreeze
http://code.google.com/p/touchfreeze/
Nov 13, 2010 | EliteGroup 557 Notebook
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
