Question about Ryobi Garden
Ryobi trimmer Rlt30CES head slow down under revs
  • 154 Answers
Sounds like a drive shaft/clutch type problem, I do not know the machine but suspect it uses a flexible shaft to the head has this union worn out or at the motor end there would be some kind of clutch which would leave the motor spinning on tick over (not the head) then engage on rev up. Perhaps this is faulty or has oil on it, could be its flexible shaft has got a worn end.
On my old B&D it throws a sprung disc out under centrifugal force to engage with its drive shaft coupler which at low revs the springs "win" to disengage it.
Its head end is easier first to check by removal of its line holder after that things are more complex with mine four screws remove what I call its nose cone to get into the clutch area.
If there is a wear issue run it at a gentle speed dabbing its head into some grass you may find the motor spins on but its head stops which will confirm the above.
Hope this helps..........
Posted on May 09, 2017
Ryobi electric hybrid weed eater quit working.
are there weeds stuck under the trimmer head causing it to work too hard perhaps and even short cords if not heavy enough will cause problems and burn out the motor
Jul 18, 2015 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How to replace fuel lines on ryobi rlt30ces line trimmer
Hope this is what your looking for.
Please rate me
Feb 15, 2013 | Ryobi Garden
I have a Ryobi RLT30CESNB whipper snipper. Had it for about a year. The motor starts and runs okay. Just yesterday, all of a sudden, the head stopped spinning when I gave it some throttle. The motor still...
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 05, 2012 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
Ryobi RLT30CES Running too Rich
Yes most of these need a special tool which costs about 70 dollars it is cheaper to get your local dealer to tune
Jul 06, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES line trimmer head problem
Many small line trimmers lack a clutch system by design so this could be normal.
May 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES instruction manual WITH 'figures'
Mar 22, 2009 | Ryobi Garden
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
