Question about Brother Sewing Machines
Brother xr1355. Putting binding on quilt. Knots up in corners. Where should tension be set? Any other ideas?
  • 110 Answers
SOURCE: Tension issue
If you set the tension from 3of 4 to 1 you actually lowered the tension. To increase the tension you must set the tension to 6 or higher. Be carefull not the set the bobbin case tension to tight as this will also have negative results
If suggest the following: First lower the bobbin case tension, half a turn. Then increase the top tension to 6 and see if there is any difference.
If you do this systematically you should rectify your problem.
Good Luck
Posted on Jan 21, 2008
  • 1116 Answers
SOURCE: I'm trying to use the Janome 1600P DBX for
I would try this -
Make sure you are not using quilting thread for hand stitching.
Thread the machine with the presser foot up.
If the machine is stitching seams without a problem and the breakage happens with thicker fabrics, it could be the presser foot is not down below where it is closing the tension to the setting of choice.
When the presser foot is up, the tension control opens. When the presser foot is down, the tension control closes to the setting you have chosen.
If this continues, call the dealer/tech and tell them the problem you are having.
Posted on Mar 06, 2010
  • 40 Answers
SOURCE: how do i set the tension on my brother xl-3010
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
Posted on Jun 01, 2010
  • 1788 Answers
SOURCE: tension problem on Brother 1500S.
Sometimes it is just a matter of totally rethreading with different thread, I was shocked when some thread that I had bought and it turned out that it was old stock (no wonder it was on sale). Another thing to try is when you rethread with the presser foot up, try this test, pull your thread, it should move smoothly, now lower the presser foot, pull the thread, it should barely move. This should seat your thread in the tension discs. Another thing to do is put in a new needle before you do your rethreading and take off your throat plate, and see it there is a burr inside the needle hole, if so take some emery cloth or light sand paper with a toothpick and go around that hole. While you have the throat plate off, take an old toothbrush and clean out all around your feed dogs. You will probably find something that looks like felt there, and it shouldn't be there. Depending on my machine (I have 5), I set my tension on 3 and some need the 4 setting, I teach disabled teens how to sew and run into alot of different easy to fix problems in my 50+ years of sewing, These are all little tricks you learn. Good luck and have a great day,
Posted on Apr 21, 2011
Testimonial: "Thankyou, I will give it a try."
SOURCE: thread tension when free motion quilting
do you have this problem when doing regular sewing? if you do then the tension dial may be going bad & would have to be replaced
Posted on Mar 14, 2012
How do i set the top tension for quilting on my brother sq9185
You will want to adjust the top tension for quilting like you do for other sewing. The tension is correct when the top and bobbin threads meet in the middle of the fabric (or quilt). Be sure to ALWAYS RAISE the presser foot when threading the top thread.
User Guide Manuals SQ9185 Others Brother (pg 43)
Dec 13, 2017 | Brother Sewing Machines
Electric flash by my new Brother XR1355 sew.machine
I would think it's more like something wrong with the receptacle rather than the machine. Try plugging it into a different plug first if that's isn't the problem. We will have to try something else.
Jan 26, 2014 | Brother Sewing Machines
Mega quilter binds thread under fabric
If you have to manually set the tension on your bobbin, your tension may be too loose or too tight. When my bobbin is full of thread the tension has to be stronger than when it is almost empty. So tight when it's full and loose when it's nearly empty. I hope this helps. If this doesn't work try using a air can to blow out the dust in your bobbin casing and make sure the bobbin doesn't have any burs. It needs to be wound smoothly. Also check for thread hangups in the bobbin casing area. Also you may want to completely re-thread your machine.
Jan 02, 2014 | Sewing Machines
I have a Brothers 1500s. When I quilt with it the stiches skip every now an then leaving a large gap between stitches. Do I have the quilt to far up from the base of hte machine when I quilt? Should the...
Your top tension is based on the fabric thickness.. not just a number. Make a test sandwich of all the materials you are quilting with, cotton top, batting, lining, etc. Test your tension on that until you get it right.
The skipping is a symptom of a bad needle or the presser foot not having enough pressure on it. I'm not familiar with your machine so I don't know if it has the ability to add more pressure to the presser foot.
Dec 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Bernina Binding Foot
check on youtube for a video
Aug 20, 2012 | Bernina Sewing Machines
Uneven stitches while machine quilting.
Are you using the right size needle and thread? Also, check tension recommended by your manual. Let me know if that helps, because I can ask my sister who has that machine
Jul 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
May 31, 2010 | Brother XL-3500
I can't find the tension adjusting spring on my brother 2600i
1Sew a test seam. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+9665908481+7416705818+8962074949+8941458308+1258424658+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2Observe the seam on the top and the bottom surface using a magnifying device if need be.
  • 3Find the position of the knots.
  • 4Tighten the tension and "pull the knots up" if the knots appear on the bottom side of the sewn seam.
  • 5Loosen the tension and "drop the knots down" if the knots are on the top surface.
  • 6Sew a test on the fabric you will be using. Tensions often have to be adjusted when changing fabric types and weights.
  • 7Continue adjusting the tension and inspecting the seam until your seam is balanced.
  • Apr 03, 2010 | Brother XL-2600I
    Needle thread breaks while quilting on machine frame
    My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
    Nov 01, 2008 | Juki TL-98Q
    Sewing Machines Logo
    24 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
