Tv cut on and off? like tv need two be reset?
    Top Expert:
  • Televison & ... Master
  • 73,647 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 29, 2017
Dynex tv cuts off resetting a/c tv comes back on??
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
May 18, 2016 | Dynex Televison & Video
47LN5200 BACKLIGHTS SHUTDOWN WHEN CUTTING TV ON KEEPS SOUND VOLTAGES CHECK BUT WHEN CUT TV OF CAN SE DIM FLASH FROM LEDS POSSIBLE EEPROM BAD?
Try a hard reset to this set, and check. If it too do not help you, the back-light inverter section circuit should be checked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 06, 2015 | LG Televison & Video
Replaced lamp. TV worked great. Never reset message code. Finally, tv started cutting off after booting up. Reset lamp code, lights on front went one green. Thought that solved problem.
After a lamp replacement, you might have to reset the lamp time. It was a must. Contact the authorized service center; as there is no chance to you to get the screen display any further. The service engineers at the service center will do the needy.
Feb 25, 2015 | Televison & Video
HOW DO I RESET MY TV. IS THERE A RESET BOTTON ON THE TV; 32MD3578
manual. walk thrue the the maual and with you temote, and then fabricreset, are you a mongole or so , reading is hard
Nov 02, 2014 | Toymax Magnavox 37MF331D 37 in. LCD TV
Power went off and when it returned unit will not progress from the Hello message
Remove the power plug and keep the set un-switched for few hours/overnight. If there is any resetting mentioned in the manual please try and reset the TV using the method described.
Now it is possible that the Tv has hung up after the surge on power after the power cut.
This might have corrupted the operating program and hence it might need a reset.
Feb 15, 2011 | Televison & Video
I am having sound issues, the volume cuts out. I read somewhere that if I change my connections to the dvd player and so forth that it might help. I tried that yesterday and it worked for about 3-4 hours...
There no sound card in LCD tvs,only a Tuner board to get air brocast signal that included sound.Tries to reset ur tv by unplug,replug the tv about an hour later.Go to the tv menu go to PICTURE down to reset.Now the Tuner board is reset to factory setting it should fix ur sound problems.Not than buy a refurbish Tuner board for the replacement.
May 25, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
For about 4 weeks in have been getting a notice when I turn the tv on about a lamp timer needed to be reset. While the TV was on it cut off by itself. This is a panasonic 43" rear projection LCD TV. It is...
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
This is the procedure for resetting the lamp timer. Have you ever replaced the lamp before? The lamps usually never last 5yrs.
Sep 30, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
Apr 17, 2009 | Mitsubishi LT-52244 TV
My tv is cutting off after about a minute on and
Look in your owners manual for how to reset the Lamp Hours and see how many hours you have on the lamp. Your doing good if you can get 3000hrs. These type of lamps when they get weak will quit and the buzzing you hear is the lamp supply starting it up again. so in short, I would say you may need a lamp. Today's sets ( DLP's) which you have, you cant judge by the age, with those it's by the hours. Hope this helps and let me know...
Mar 13, 2009 | Hitachi 50VS69 50" Projection HDTV
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
