Question about Garden
My lawn mower wont start it is not getting gas and the primer blub has no prime
    Habit-Forming:
    New Friend:
  • 16 Answers
Ok first of all you need to unplug the plug wire to prevent it from sparking. Make sure you're in a ventilated area. Shut the fuel valve off if it has one. Remove the carburetor and make sure to note how it comes apart so you can put it back together. (Note if you can get to the drain plug skip removing the carb for now) Open up the fuel bowl drain plug and if no fuel comes out its more than likely a clogged fuel line or in the tank itself. Remove it all and use carb cleaner and blow it with compressed air especially the inside of the tank but soak up what fuel is in there after draining with a clean shop paper towel. The thick blue ones. Most small yard equipment doesn't have fuel pumps and are gravity fed and the lines must be clean for the fuel to get to the carb. In you're case to the blub. Reason for all this is bad fuel these days with ethanol. Two ways to prevent this headache. First drain all the fuel every fall/winter or use sta-bil fuel additive in the tank and run it long enough to go thru the lines and carb before turning it off. Works for me. Good luck any let me know how it went.
Posted on Apr 28, 2017
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
Primer bulb removal on a 1994 vantage 35 mower how do you remove the bulb
most lawn mower primer blubs have a metal ring holding the base in. Just uses use a small screw drive or hook and drag in out.
Feb 04, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Gas is pouring out of primer bulb, Dancel in distress.
Sometimes the screws around the blub come loose, tighten
them. Or may a crack in primer bulb.
Sep 10, 2012 | Toro Power Lawn Mower
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
