Question about Alpine Car Audio & Video
How do I connect phone n Bluetooth together on my alpine cda 105
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
SOURCE: Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Posted on Sep 29, 2008
  • 11 Answers
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
SOURCE: Change illumination colour Alpine CDA 9853
1. Go to menu
2. Using touchbar go to 2nd function
3. Using touchbar choose a preset colour or tap P1 at the end on the touchbar and use the volume round thingy to choose your own colour by turning the volume knob.
Posted on Nov 17, 2009
I need to download a user manual for my alpine cd player(CDA-105)
You can download and print the instruction manual for Alpine CDA-105 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 02, 2011 | Alpine CDA-105Ri CD Players
My Alpine cda-105 restarts/resets when I turn it up!
hi there it souds like the units thermal cut out is faulty it cold also be a lack of power a capacitor wuoldnt make a difference try taking a live direct from the battery this eliminates the lack of power sinario hope this helps ben
Oct 12, 2009 | Alpine CDA-105Ri CD Players
Have an alpine 9886 stereo and cannot connect my blue tooth ready phone...
Hello maslynab,
The Alpine CDA-9886 is Bluetooth ready but requires an adapter such as Alpine's KCE-400BT or a generic adapter in order to pair with a phone.
Hope this helps.
Aug 05, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Apr 17, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Car Audio & Video Logo
55 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
