Question about Blanco Ovens
Blanco oven clock and timer are working but not the oven ?
SOURCE: F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Posted on Nov 13, 2008
  • 979 Answers
SOURCE: timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Posted on Feb 03, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 17130 Answers
SOURCE: My Bosch double oven timer
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Posted on Sep 19, 2010
Testimonial: "Thanks caroldon, but it sounds complicated. How do I check the transformer?"
SOURCE: Need Chambers Oven clock/timer unit, model #GBO-244
Posted on Oct 07, 2012
I'm after a blanco oven manual for BSO632. The
Blanco Oven
Sep 20, 2014 | Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
How do we make the oven work?
Have a look 1/2 way down this page: BCG95W and others are listed. Regards.
May 25, 2010 | Ovens
Ovens Logo
50 people viewed this question
Top Blanco Ovens Experts
ray gallant
Are you a Blanco Oven Expert? Answer questions, earn points and help others
